Restore doesnt restore anything
I used Automatic Google Drive backup plugin, and hoped it was enough. Surely my SD card blew again and i tried to restore from the backup - only things that are restored are my Add-ons.
No automations, not my lovelace config or anything. The tar file shows some folders - is there hope somehow to still restore from the backup?
The log says 20-05-04 19:24:43 INFO (MainThread) [supervisor.snapshots] Full-Restore bd4e34ae done like its ok. But i see nothing except some add-ons.
After manually copying the config folder extracted from backups tar file - it doesnt even boot.
Having this same issue… Trying to move from virtualbox to a NUC. Acts like it restores fine, but the only thing showing up is a couple of addons. I can open up the snapshot .tar and browse through it fine, everything is in there. Same HA and hassio versions. Tried with multiple snapshots.
Did you get anywhere with this?
Same problem. Restoring fresh backup on different SD card (last RPI4 image) and this is still default:
configuration.yaml
ESPHome
Themes
