Hi, I am trying to test a restore from a full backup, but having no luck,
this is my setup
Home Assistant 2023.6.2
Supervisor 2023.06.2
Operating System 10.2
Frontend 20230608.0 - latest
I do a full backup, shut down my VM, spin up a new VM from an .OVA file, I try to restore from the backup, but the session just disconnects and nothing happens, nothing in the logs if I restart the VM.
i have loads of add-ons (inc HACS) and devices, any help would be appreciated…
I currently do an entire VM back up ~20G or so to another NAS and then cloud; just exploring a smaller backup solution; you do not have a backup, unless you test the restore process
After your explanation, I’m not sure what you’re doing in this step
Is this ova file HA OS or just a plain VM? Sorry, I’m using Proxmox and not VMware.
The “normal” way would be, you setup your VM, load the version of HA OS corresponding to your backup and let it install. After the initial install you will get to the “onboarding” screen, where you can setup the Admin user OR restore a backup. That’s where you choose your backup and it should install. After some waiting time, depending on your backup size, the system will restart, and you should be presented by your login screen. Backup is now restored, everything should be there.
thanks for the reply, TBH, its rather embarrassing, I cannot remember how I initially created the VM instance a few years ago, its gone through so many upgrades - I am using QNAP and Virtualization Station. Its got me thinking I did not import an image with a .OVA file
