Restore from snapshot from 64bits to 32bits
Dear all,
I have running HA on 64bits. But due to issues with bluetooth I would like to move to 32bits. I’ve created a snapshot and wanted to restore it in 32bit version. Apparently after 10-15 minutes, HA is restarted but configuration is not restored… Is it possible to use snapshot from 64bit in 32bit? Or I need to install 32bit version and re-create all configs manually?
Cheers
Bartek
Should be… just make sure, while doing restore, that you only select Home Assistant Configuration, not the rest of the setup.
Alternative is to manually unarchive snapshot and restore configuration files (like configuration.yaml) manually, directly to config folder.
