Restore Hassio
Hello today, after energy power down my raspberry pi sd card goes corrupt.
I installed a new image, and now I’m trying to restore a snapshot from yesterday.
from ssh I receive this error when I execute the command hassio sn restore -slu 49d172a7
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2f8720, 0x442013a140)
        /home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x390
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x4420142000, 0x24, 0x200, 0x0)
        /home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x404
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x344c30, 0x9, 0x44200d2f80, 0x15, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, ...)
        /home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x31c
github.com/home-assistant/hassio-cli/command.CmdSnapshots(0x44200829a0)
        /home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/snapshots.go:75 +0x568
github.com/urfave/cli.HandleAction(0x2dc640, 0x373008, 0x44200829a0, 0x0, 0x0)
        /home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0x118
github.com/urfave/cli.Command.Run(0x344c30, 0x9, 0x0, 0x0, 0x49a2d0, 0x1, 0x1, 0x34f1d2, 0x28, 0x0, ...)
        /home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x7b0
github.com/urfave/cli.(*App).Run(0x44200e2000, 0x442000a0f0, 0x5, 0x5, 0x0, 0x0)
        /home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x950
main.main()
        /home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x150
If I use GUI the log shows:
8-08-15 20:29:27 INFO (MainThread) [hassio.snapshots] Restore 49d172a7 wait for Home-Assistant
18-08-15 20:29:27 WARNING (MainThread) [hassio.homeassistant] Version 0.75.3 is already installed
18-08-15 20:29:28 ERROR (MainThread) [hassio.snapshots] Restore 49d172a7 error
  File "/usr/local/lib/python3.7/site-packages/hassio/snapshots/__init__.py", line 330, in do_restore_partial
    await self.sys_homeassistant.start()
  File "/usr/local/lib/python3.7/site-packages/hassio/utils/__init__.py", line 25, in wrap_api
    return await method(api, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/hassio/homeassistant.py", line 278, in _start
    raise HomeAssistantError()
hassio.exceptions.HomeAssistantError
Any help?
do you have another snapshot? that one might be corrupt?
I tested with old backup and a received the same error.
Perhaps try a new SD-Card? Is your power supply the correct rating?
Forget it, I reintalled Hassio in same SD card, now I’m configuring all again.
Future: I will configure ftp backup instead of snapshot
