IF you cannot do that, inside the backup there is a homeassistant.tar.gz.
Inside homeassistant.tar.gz there is ā/dataā folder that appears to be backup of the full HA config folder
Create homeassitant container
Run homeassistant container and verify you get setup or login screen
Stop homeassistant container.
Replace current homeassistant /config folder with full contents (including hidden folders) of /data from backup
Restart homeassistant container. All should work
NOTE
Version of backup should match version of container. Do not restore config from 2022.3.1 to 2022.9.1 or even 2022.9.1 to 2022.9.3. If you want to update do that after restore. The backup is named after the version and docker tags allow you to restore specific version so it should be easy to manage.
The container itself does not need a backup, you can pull this āanytimeā from docker
The duplicati setup I have does only do backs-up for the persistent part of my containers and duplicati allows to restore single files
Iām having the same problem.
Iām stuck at this part : Replace current homeassistant /config folder with full contents (including hidden folders) of /data from backup
How you manage to do that ? Iām not an expert with Docker and containers.
Nevermind, I managed to do it.
But when I log in to the interface of Home Assistant, iām still welcomed by the onboarding screen, and cannot access to whatever I had configured before.
When I access the container via portainer I can see itās got all my files and configurations under itās config folder ā¦
I did check whatās inside the config folder and there is my custom_components, my config file refers to devices etc
I also reconfigured mqtt broker in the devices page and all my zigbees devices were automaticly configured. So I assume it has loaded my configuration but not totally.
But, I need to reconfigure lots of things that I should not have to : dashboards, persons, devices etc
I donāt have a .secrets folder neither in my backup folder or in my config folder.
No relevant information in portainer logs during startup
EDIT :
Ok, I managed to get it working.
In fact, I used cp command to copy my files BUT without the -R it doesnāt copy the hidden folders.
When I started Home Assistant container, it created the missing folders so when I checked if everything was ok, it seemed, indeed.
But, then I checked their content and compared to my backup and there were some files missing, a lot in fact.
Thankās for your help and I hope it will contribute to helping others.
