Hi all i have a Proxmox server with some VMs, i installed HA using the haos_ova-10.1.qcow2 image.
ha starts empty but when i try to restore a bakup (only ha and folder for the first time) from my rpi4 it thake many times up to 90 minutes.
HA restore contain version 2023.5.3
(i tried OS 9.5 and 10.2 but with same issue)
from the supervisor log i can see:
May 25 12:18:16 homeassistant hassio_supervisor[436]: 23-05-25 14:18:16 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
May 25 12:18:21 homeassistant hassio_supervisor[436]: 23-05-25 14:18:21 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
May 25 12:18:40 homeassistant hassio_supervisor[436]: 23-05-25 14:18:40 INFO (SyncWorker_2) [supervisor.backups.backup] Restore folder share done
May 25 12:18:40 homeassistant hassio_supervisor[436]: 23-05-25 14:18:40 INFO (MainThread) [supervisor.backups.manager] Restoring 15a886ed Home Assistant Core
May 25 12:18:40 homeassistant hassio_supervisor[436]: 23-05-25 14:18:40 INFO (SyncWorker_3) [supervisor.docker.interface] Stopping homeassistant application
May 25 12:22:13 homeassistant hassio_supervisor[436]: 23-05-25 14:22:13 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.FREEZE
May 25 12:22:13 homeassistant hassio_supervisor[436]: 23-05-25 14:22:13 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
May 25 12:26:13 homeassistant hassio_supervisor[436]: 23-05-25 14:26:13 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.FREEZE
May 25 12:26:13 homeassistant hassio_supervisor[436]: 23-05-25 14:26:13 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
May 25 12:26:16 homeassistant hassio_supervisor[436]: 23-05-25 14:26:16 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
after the last message i can see the supervisor remain at 98-100% cpu usage for 90 minues:
after this the ha starts fine.
hdd speed test:
all other VMs works fine
this issue is present with all VMs off too.
someone have encouter this?
