Hi, I’ve moved from a Rpi3 to a Rpi4. Setting up the Rpi4 on Hass.os did work and I could access my UI and als install Add-ons. then I moved over my backup folder from the Rpi3 which also was running on Hass,.os and restored my latest backup.
After that, I was unable to access the Home Assistant Web UI.
When I try to start home assistant from the shell, I get also an error after a while;
core-ssh:/config# hassio ha start
Processing... Done.
Error: Unknown Error, see logs
Unfortunately I am stuck with troubleshooting. I did not find any issues in the /configuration/home-assistant.log. There are just two integrations that could not initialized (Tradfri, WeatherUnderground).
How can I troubleshoot the issue or is there any better way to migrate my HA to the new hardware?
