You’ll need to set up your git configuration (email, ssh etc if relevant) definitely, but I don’t think you do git init off the top of my head, because I think that will create a new, blank git commit history.
Please note that this is an educated guess, I may be completely wrong, I have lots of trouble remembering which bits affect what in git/github too!
will create a directory wherever you are called my-git-ha-repo (obviously whatever your repo is actually called) If you use git clone https://my-git-ha-repo . (note the .) it will dump the contents of your repo directly in the folder you are currently in.
git init is for actually creating a NEW repo, so no, if you are cloning a repo, you do NOT run init. If you are using git https:// then you also do not need to config anything, but in order to commit changes you will need to run git config. Git config is a way of setting your login/pass/etc
If you plan to make changes to this installation, and push them back to github, I think you will need to (or at least its easier to) set up ssh keys in github and use the git protocol.
OK, so once I have cloned and config’d, I should be able to run git status for example, and also commit local changes to the remote backup with git add file.yaml and git commit
