Restore previous state after power failure - light
I’m still new to both HA and ESPHome and I’m looking for a bit of help. I recently used tuya-cloudcutter to flash ESP on to some Merkury Innovation lights (MI-BW210-999WW) and have built a sunset/sunrise automation.
The lights are connected to a physical switch and sometimes they have been accidently switched off when the lights are on. When the switch is flipped back on, the lights reconnect but don’t turn back on. I have done some research seen “esp8266_restore_from_flash”, “on-boot” and “restore_mode” but none of them either make sense to me or completely answer my question.
Below is my yaml file for one of the lights. Any help is greatly appericated.
esphome:
libretiny:
  board: generic-bk7231t-qfn32-tuya
  framework:
    version: dev
logger:
web_server:
captive_portal:
mdns:
api:
  password: !secret api_password
  encryption:
    key: !secret api_encrypt_driveway-light-right
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: !secret ip_driveway-light-right
    # Set this to the IP address of the router. Often ends with .1
    gateway: !secret ip_gateway
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: !secret ip_subnet
button:
- platform: restart
debug:
  update_interval: 30s
text_sensor:
- platform: debug
  reset_reason:
- platform: libretiny
  version:
- platform: uptime
bp5758d:
  clock_pin: P8
  data_pin: P7
output:
- platform: bp5758d
  channel: 3
  current: 29
- platform: bp5758d
  channel: 2
  current: 29
- platform: bp5758d
  channel: 1
  current: 29
- platform: bp5758d
  channel: 5
  current: 65
light:
- platform: rgbw
  red: output_red
  green: output_green
  blue: output_blue
  white: output_cold
To start with a disclaimer: I am not familiar with libretiny or the lamp that you’re using. I’m therefore not sure if it has flash memory to store values which ‘survives’ a restart.
For a ‘regular’ ESP8266 or ESP32 you can make use of globals to store and restore values as follows:
esphome:
  on_boot:
    then:
      - light.control:
          state: !lambda
            return id(last_light_state);
esp8266:
  board: ...
  restore_from_flash: true  # only needed for esp8266
globals:
  - id: last_light_state
    type: boolean
    restore_value: yes
    initial_value: 'false'
light:
  - platform: ...
    on_turn_on:
      - globals.set:
          value: 'true'
    on_turn_off:
      - globals.set:
          value: 'false'
The restore_value tries to read value from the memory upon (re)start. The on_boot part sets the light state based on the last known state.
Finally, the light. Each time it’s switched on or off, would save the new state in the globals.
Didn’t seem like those worked. I’ll keep searching the documentation. Thanks for attempt!
It does work, but, the state of the light will only be stored in the flash memory after 1 minute because of this breaking change that will preserve your flash memory:
ESPHome 2023.4.0 - 19th April 2023
You can edit the write interval with this line:
preferences:
    flash_write_interval: example #(time in seconds e.g. 30s)
