Flashed SD with same install of Hassio. Installed Samba addon to put my snapshot into. Rebooted system… Snapshot allocated and told to wipe and restore. 443 to 8123 is still active… After the restore and boot I can’t access my duckdns or local URL to HA. I can access Samba and this is what the log file is showing.
2019-12-22 22:03:14 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key "script". Check lines 7 and 142.
2019-12-22 22:03:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for wyzesense which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-22 22:03:29 WARNING (MainThread) [zigpy.zdo] [0x0000:zdo] Unknown ZDO cluster 0x8038
2019-12-22 22:04:06 ERROR (SyncWorker_5) [homeassistant.components.wemo] Unable to get description url for WeMo at: 192.168.1.34
2019-12-22 22:36:52 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-22 22:52:50 ERROR (SyncWorker_0) [homeassistant.components.yeelight] Unable to update device 192.168.1.32, Yee Desk: A socket error occurred when sending the command.
2019-12-22 23:34:14 ERROR (SyncWorker_19) [homeassistant.components.yeelight] Unable to update device 192.168.1.31, Yee Guest: Bulb closed the connection.
2019-12-23 01:17:37 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 14:13:12 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 16:24:27 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 16:24:32 WARNING (SyncWorker_19) [pywemo.ouimeaux_device.api.service] Error communicating with Front Room, retry 0
2019-12-23 16:37:40 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-23 16:37:52 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-23 17:15:36 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 17:15:47 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 19:24:36 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 20:16:29 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-23 20:16:34 WARNING (SyncWorker_13) [pywemo.ouimeaux_device.api.service] Error communicating with Front Room, retry 0
2019-12-23 21:27:51 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-23 21:27:57 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-23 21:28:01 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-23 21:28:02 WARNING (MainThread) [zigpy.zdo] [0x0000:zdo] Unknown ZDO cluster 0x8038
2019-12-23 21:28:03 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-23 21:32:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-12-23 22:48:14 ERROR (SyncWorker_8) [homeassistant.components.yeelight] Unable to update device 192.168.1.32, Yee Desk: Bulb closed the connection.
2019-12-23 23:22:24 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-24 11:17:43 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook 731d5e435c260c66503af98cc5d19d6de4e6cc8ef1b324b9c397556750b2f38e
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 77, in async_handle_webhook
response = await webhook["handler"](hass, webhook_id, request)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 278, in handle_webhook
await hass.data[DOMAIN][DATA_STORE].async_save(safe)
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 137, in async_save
await self._async_handle_write_data()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 198, in _async_handle_write_data
self._write_data, self.path, data
concurrent.futures._base.CancelledError
2019-12-24 12:36:59 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-24 12:37:00 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_lamps. Invalid data for call_service at pos 1: extra keys not allowed @ data['data']
2019-12-24 13:42:39 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-24 13:42:44 WARNING (SyncWorker_13) [pywemo.ouimeaux_device.api.service] Error communicating with Front Room, retry 0
2019-12-24 13:56:54 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-24 15:49:44 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-12-24 16:18:22 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
2019-12-24 17:09:21 WARNING (MainThread) [homeassistant.components.wemo.switch] Lost connection to Front Room
Any help would be greatly appreciated.
