Hi, I have a power outlet and it’s working fine but after reboot or home assistant restart, the switch is powered on (it has voltage) but shows as off in HA
# gosund sp111 smart plug with power sensor
substitutions:
devicename: "gosundsp111"
upper_devicename: "Gosund SP111"
# Higher value gives lower watt readout
current_res: "0.00230"
# Lower value gives lower voltage readout
voltage_div: "733"
esphome:
platform: ESP8266
board: esp8285
esp8266_restore_from_flash: true
# WiFi connection
wifi:
ssid: !secret wifi_ssid
fast_connect: on
manual_ip:
static_ip: !secret static_ip
gateway: !secret gateway
subnet: 255.255.255.0
ap:
# ssid: "gosund-sp111"
ssid: "${devicename} Hotspot"
password: !secret hotspot_password
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable over-the-air updates
ota:
# Enable Web server
web_server:
port: 80
auth:
username: admin
password: !secret web_server_password
time:
- platform: homeassistant
text_sensor:
- platform: version
name: "${devicename} - Version"
icon: mdi:cube-outline
binary_sensor:
- platform: status
name: "${devicename} - Status"
device_class: connectivity
# toggle relay on/off
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: button_switch
- platform: wifi_signal
name: "${devicename} - Wifi Signal"
update_interval: 60s
icon: mdi:wifi
- platform: uptime
name: "${devicename} - Uptime"
icon: mdi:clock-outline
- platform: total_daily_energy
name: "${devicename} - Todays Usage"
power_id: "power_wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
icon: mdi:calendar-clock
- platform: adc
pin: VCC
name: "${devicename} - VCC Volt"
icon: mdi:flash-outline
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO04
change_mode_every: 4
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
update_interval: 3s
current:
name: "${devicename} - Ampere"
unit_of_measurement: A
accuracy_decimals: 3
icon: mdi:current-ac
voltage:
name: "${devicename} - Volt"
unit_of_measurement: V
accuracy_decimals: 1
power:
name: "${devicename} - Watt"
unit_of_measurement: W
icon: mdi:gauge
status_led:
pin:
number: GPIO02
inverted: True
output:
- platform: gpio
pin: GPIO00
inverted: true
switch:
name: "${devicename} - Switch"
icon: mdi:power
optimistic: true
turn_on_action:
- switch.turn_on: relay
turn_off_action:
- switch.turn_off: relay
- platform: gpio
pin: GPIO15
