Restore switch states on power on
I am using an esp32 running esphome as a control panel for home assistant.
is there a way on restarting the esp32 for it to poll home assistant for the state of certain switches?
so for example i have a bipolar led that shows is a certain door is open or not - this is managed through home assistant and hows on the dashboard etc - so pins 19 and 21 are red and green on the led (with an interlock) if i lose power to the esp 32, is there a way for esp home to query home assistant for the setting.
or, is there a way for home assistant to see when a esphome instance becomes available and send those results to the esphome? I tend to use node-red more than automation, but happy to use either.
Many thanks for you help in advace.
In ESPHome, use the on-boot trigger to call the update component action for all the entities you want to update.
Thank you.
Does that call an update from home assistant. I up trying to update esphome with date in home assistant.
To get the data from home assistant into ESPHome you must have used something like this: Home Assistant Binary Sensor ā€” ESPHome if so, yes it should update that.
Iā€™m guessing here because you have not shared your ESPHome config.
apologies, i should have shared my script, the switches get set by home assistant via a state change in nide red.
esphome:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: "xxxxxxxxxxx"
  password: "xxxxxxxxxxx"
  ap:
    ssid: "House Monitor Fallback Hotspot"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
switch:
  - platform: gpio
    pin: 15
    inverted: yes
  - platform: gpio
    pin: GPIO19
    interlock: [Boys_door_green]
  - platform: gpio
    pin: GPIO21
    interlock: [Boys_door_red]
  - platform: gpio
    pin: GPIO22
    interlock: [jonPC_red]
  - platform: gpio
    pin: GPIO23
    interlock: [jonPC_green]
  - platform: gpio
    pin: GPIO2
    interlock: [GamePC_red]
  - platform: gpio
    pin: GPIO4
    interlock: [GamePC_green]
  - platform: gpio
    pin: GPIO05
    interlock: [spare_red]
  - platform: gpio
    pin: GPIO18
    interlock: [spare_green]
  - platform: gpio
    pin: GPIO27
    optimistic: true
    turn_on_action:
    - switch.turn_on: recycling
    - delay: 500ms
    - switch.turn_off: recycling
    - delay: 500ms
  # turn self on again if still enabled
    - if:
        condition:
          lambda: 'return id(Recycling_flash).state;'
        then:
        - switch.turn_on: Recycling_flash
    turn_off_action:
  - platform: gpio
    pin: GPIO13
    optimistic: true
    turn_on_action:
    - switch.turn_on: bins
    - delay: 500ms
    - switch.turn_off: bins
    - delay: 500ms
    - if:
        condition:
          lambda: 'return id(bins_flash).state;'
        then:
        - switch.turn_on: bins_flash
    turn_off_action:
binary_sensor:
  - platform: gpio
    pin:
      number: 33
      mode: INPUT_PULLUP
      inverted: true
    filters:
    - delayed_on: 50ms
  - platform: gpio
    pin:
      number: 25
      mode: INPUT_PULLUP
      inverted: true
    filters:
    - delayed_on: 50ms
  - platform: gpio
    pin:
      number: 34
      mode: INPUT
      inverted: true
    filters:
    - delayed_on: 50ms
  - platform: gpio
    pin:
      number: 32
      mode: INPUT_PULLUP
      inverted: true
    filters:
    - delayed_on: 50ms
