thank you for your reply.
There is approximately 20 nodes in my network.
I posted the partial content of my OZW_Log.txt because he’s too long.
It could be great if I could restore the zwave network
2019-08-07 09:30:27.567 Always, OpenZwave Version 1.4.3440 Starting Up
2019-08-07 09:30:46.080 Info, Setting Up Provided Network Key for Secure Communications
2019-08-07 09:30:46.080 Info, mgr, Added driver for controller /dev/ttyACM0
2019-08-07 09:30:46.081 Info, Opening controller /dev/ttyACM0
2019-08-07 09:30:46.081 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-08-07 09:30:46.083 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-08-07 09:30:46.083 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-08-07 09:30:46.084 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-08-07 09:30:46.084 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-08-07 09:30:46.084 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-08-07 09:30:46.084 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-08-07 09:30:46.084 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-08-07 09:30:46.087 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x35, 0x00, 0x01, 0x99
2019-08-07 09:30:46.087 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2019-08-07 09:30:46.087 Info, contrlr, Static Controller library, version Z-Wave 3.95
2019-08-07 09:30:46.087 Detail, Node045, Expected reply was received
2019-08-07 09:30:46.087 Detail, Node045, Message transaction complete
2019-08-07 09:30:46.087 Detail, contrlr, Removing current message
2019-08-07 09:30:46.088 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-08-07 09:30:46.091 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xc3, 0xfe, 0x98, 0xd9, 0x01, 0xab
2019-08-07 09:30:46.091 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc3fe98d9. Our node ID = 1
2019-08-07 09:30:46.091 Detail, Node254, Expected reply was received
2019-08-07 09:30:46.091 Detail, Node254, Message transaction complete
2019-08-07 09:30:46.091 Detail, contrlr, Removing current message
2019-08-07 09:30:46.092 Detail,
2019-08-07 09:30:46.092 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-08-07 09:30:46.094 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2019-08-07 09:30:46.094 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2019-08-07 09:30:46.094 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2019-08-07 09:30:46.094 Info, contrlr, The PC controller is a primary controller.
2019-08-07 09:30:46.094 Detail, Node247, Expected reply was received
2019-08-07 09:30:46.094 Detail, Node247, Message transaction complete
2019-08-07 09:30:46.095 Detail,
2019-08-07 09:30:46.095 Detail, contrlr, Removing current message
2019-08-07 09:30:46.095 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-08-07 09:30:46.099 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x00, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfb
2019-08-07 09:30:46.099 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2019-08-07 09:30:46.100 Info, contrlr, Serial API Version: 1.0
2019-08-07 09:30:46.100 Info, contrlr, Manufacturer ID: 0x0086
2019-08-07 09:30:46.100 Info, contrlr, Product Type: 0x0001
2019-08-07 09:30:46.100 Info, contrlr, Product ID: 0x005a
2019-08-07 09:30:46.100 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-08-07 09:30:46.100 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-08-07 09:30:46.100 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-08-07 09:30:46.100 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-08-07 09:30:46.100 Detail, Expected reply was received
2019-08-07 09:30:46.101 Detail, Message transaction complete
2019-08-07 09:30:46.101 Detail, contrlr, Removing current message
2019-08-07 09:30:46.101 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-08-07 09:30:46.103 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2019-08-07 09:30:46.109 Detail,
2019-08-07 09:30:46.110 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2019-08-07 09:30:46.110 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2019-08-07 09:30:46.110 Detail, Node172, Expected reply was received
2019-08-07 09:30:46.110 Detail, Node172, Message transaction complete
2019-08-07 09:30:46.110 Detail, contrlr, Removing current message
2019-08-07 09:30:46.110 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-08-07 09:30:46.166 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xec, 0x90, 0x46, 0x35, 0x26, 0x47, 0xfb, 0xd2, 0x67, 0x55, 0xa1, 0x8f, 0x1c, 0x2c, 0x4e, 0xa2, 0x46, 0xe2, 0x54, 0x9e, 0x1c, 0x1b, 0xcc, 0x39, 0x8b, 0xc5, 0x20, 0xfc, 0x14, 0x41, 0xd2, 0xf4, 0x1c
2019-08-07 09:30:46.166 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2019-08-07 09:30:46.166 Detail, Node032, Expected reply was received
2019-08-07 09:30:46.166 Detail, Node032, Message transaction complete
2019-08-07 09:30:46.167 Detail,
2019-08-07 09:30:46.167 Detail, contrlr, Removing current message
2019-08-07 09:30:46.167 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-08-07 09:30:46.269 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0xdd, 0xfa, 0x98, 0x70, 0x3b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0x30
2019-08-07 09:30:46.269 Info, mgr, Driver with Home ID of 0xc3fe98d9 is now ready.
2019-08-07 09:30:46.269 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2019-08-07 09:30:46.269 Info, contrlr, Node 001 - New
2019-08-07 09:30:46.269 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.270 Detail, Node001, QueryStage_ProtocolInfo
2019-08-07 09:30:46.270 Detail, Node001, Queuing (Query) Get Node Protocol Info (Node=1): 0x01, 0x04, 0x00, 0x41, 0x01, 0xbb
2019-08-07 09:30:46.270 Detail, Node001, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.270 Info, Node001, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.270 Info, contrlr, Node 003 - New
2019-08-07 09:30:46.270 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.270 Detail, Node003, QueryStage_ProtocolInfo
2019-08-07 09:30:46.270 Detail, Node003, Queuing (Query) Get Node Protocol Info (Node=3): 0x01, 0x04, 0x00, 0x41, 0x03, 0xb9
2019-08-07 09:30:46.270 Detail, Node003, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.271 Info, Node003, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.271 Info, contrlr, Node 004 - New
2019-08-07 09:30:46.271 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.271 Detail, Node004, QueryStage_ProtocolInfo
2019-08-07 09:30:46.271 Detail, Node004, Queuing (Query) Get Node Protocol Info (Node=4): 0x01, 0x04, 0x00, 0x41, 0x04, 0xbe
2019-08-07 09:30:46.271 Detail, Node004, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.271 Info, Node004, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.271 Info, contrlr, Node 005 - New
2019-08-07 09:30:46.271 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.271 Detail, Node005, QueryStage_ProtocolInfo
2019-08-07 09:30:46.271 Detail, Node005, Queuing (Query) Get Node Protocol Info (Node=5): 0x01, 0x04, 0x00, 0x41, 0x05, 0xbf
2019-08-07 09:30:46.271 Detail, Node005, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.272 Info, Node005, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.272 Info, contrlr, Node 007 - New
2019-08-07 09:30:46.272 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.272 Detail, Node007, QueryStage_ProtocolInfo
2019-08-07 09:30:46.272 Detail, Node007, Queuing (Query) Get Node Protocol Info (Node=7): 0x01, 0x04, 0x00, 0x41, 0x07, 0xbd
2019-08-07 09:30:46.272 Detail, Node007, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.272 Info, Node007, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.272 Info, contrlr, Node 008 - New
2019-08-07 09:30:46.272 Detail, Node008, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.272 Detail, Node008, QueryStage_ProtocolInfo
2019-08-07 09:30:46.272 Detail, Node008, Queuing (Query) Get Node Protocol Info (Node=8): 0x01, 0x04, 0x00, 0x41, 0x08, 0xb2
2019-08-07 09:30:46.272 Detail, Node008, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.273 Info, Node008, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.273 Info, contrlr, Node 010 - New
2019-08-07 09:30:46.273 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.273 Detail, Node010, QueryStage_ProtocolInfo
2019-08-07 09:30:46.273 Detail, Node010, Queuing (Query) Get Node Protocol Info (Node=10): 0x01, 0x04, 0x00, 0x41, 0x0a, 0xb0
2019-08-07 09:30:46.273 Detail, Node010, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.273 Info, Node010, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.273 Info, contrlr, Node 012 - New
2019-08-07 09:30:46.273 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.273 Detail, Node012, QueryStage_ProtocolInfo
2019-08-07 09:30:46.273 Detail, Node012, Queuing (Query) Get Node Protocol Info (Node=12): 0x01, 0x04, 0x00, 0x41, 0x0c, 0xb6
2019-08-07 09:30:46.274 Detail, Node012, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.274 Info, Node012, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.274 Info, contrlr, Node 013 - New
2019-08-07 09:30:46.274 Detail, Node013, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.274 Detail, Node013, QueryStage_ProtocolInfo
2019-08-07 09:30:46.274 Detail, Node013, Queuing (Query) Get Node Protocol Info (Node=13): 0x01, 0x04, 0x00, 0x41, 0x0d, 0xb7
2019-08-07 09:30:46.274 Detail, Node013, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.274 Info, Node013, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.274 Info, contrlr, Node 014 - New
2019-08-07 09:30:46.274 Detail, Node014, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.274 Detail, Node014, QueryStage_ProtocolInfo
2019-08-07 09:30:46.275 Detail, Node014, Queuing (Query) Get Node Protocol Info (Node=14): 0x01, 0x04, 0x00, 0x41, 0x0e, 0xb4
2019-08-07 09:30:46.275 Detail, Node014, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.275 Info, Node014, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.275 Info, contrlr, Node 015 - New
2019-08-07 09:30:46.275 Detail, Node015, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.275 Detail, Node015, QueryStage_ProtocolInfo
2019-08-07 09:30:46.275 Detail, Node015, Queuing (Query) Get Node Protocol Info (Node=15): 0x01, 0x04, 0x00, 0x41, 0x0f, 0xb5
2019-08-07 09:30:46.275 Detail, Node015, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.275 Info, Node015, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.275 Info, contrlr, Node 016 - New
2019-08-07 09:30:46.275 Detail, Node016, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.275 Detail, Node016, QueryStage_ProtocolInfo
2019-08-07 09:30:46.276 Detail, Node016, Queuing (Query) Get Node Protocol Info (Node=16): 0x01, 0x04, 0x00, 0x41, 0x10, 0xaa
2019-08-07 09:30:46.276 Detail, Node016, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.276 Info, Node016, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.276 Info, contrlr, Node 020 - New
2019-08-07 09:30:46.276 Detail, Node020, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.276 Detail, Node020, QueryStage_ProtocolInfo
2019-08-07 09:30:46.276 Detail, Node020, Queuing (Query) Get Node Protocol Info (Node=20): 0x01, 0x04, 0x00, 0x41, 0x14, 0xae
2019-08-07 09:30:46.276 Detail, Node020, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.276 Info, Node020, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.276 Info, contrlr, Node 021 - New
2019-08-07 09:30:46.276 Detail, Node021, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.276 Detail, Node021, QueryStage_ProtocolInfo
2019-08-07 09:30:46.277 Detail, Node021, Queuing (Query) Get Node Protocol Info (Node=21): 0x01, 0x04, 0x00, 0x41, 0x15, 0xaf
2019-08-07 09:30:46.277 Detail, Node021, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.277 Info, Node021, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.277 Info, contrlr, Node 024 - New
2019-08-07 09:30:46.277 Detail, Node024, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.277 Detail, Node024, QueryStage_ProtocolInfo
2019-08-07 09:30:46.277 Detail, Node024, Queuing (Query) Get Node Protocol Info (Node=24): 0x01, 0x04, 0x00, 0x41, 0x18, 0xa2
2019-08-07 09:30:46.277 Detail, Node024, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.277 Info, Node024, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.277 Info, contrlr, Node 029 - New
2019-08-07 09:30:46.277 Detail, Node029, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.277 Detail, Node029, QueryStage_ProtocolInfo
2019-08-07 09:30:46.278 Detail, Node029, Queuing (Query) Get Node Protocol Info (Node=29): 0x01, 0x04, 0x00, 0x41, 0x1d, 0xa7
2019-08-07 09:30:46.278 Detail, Node029, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.278 Info, Node029, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.278 Info, contrlr, Node 030 - New
2019-08-07 09:30:46.278 Detail, Node030, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.278 Detail, Node030, QueryStage_ProtocolInfo
2019-08-07 09:30:46.278 Detail, Node030, Queuing (Query) Get Node Protocol Info (Node=30): 0x01, 0x04, 0x00, 0x41, 0x1e, 0xa4
2019-08-07 09:30:46.278 Detail, Node030, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.278 Info, Node030, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.278 Info, contrlr, Node 031 - New
2019-08-07 09:30:46.278 Detail, Node031, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.278 Detail, Node031, QueryStage_ProtocolInfo
2019-08-07 09:30:46.279 Detail, Node031, Queuing (Query) Get Node Protocol Info (Node=31): 0x01, 0x04, 0x00, 0x41, 0x1f, 0xa5
2019-08-07 09:30:46.279 Detail, Node031, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.279 Info, Node031, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.279 Info, contrlr, Node 033 - New
2019-08-07 09:30:46.279 Detail, Node033, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.279 Detail, Node033, QueryStage_ProtocolInfo
2019-08-07 09:30:46.279 Detail, Node033, Queuing (Query) Get Node Protocol Info (Node=33): 0x01, 0x04, 0x00, 0x41, 0x21, 0x9b
2019-08-07 09:30:46.279 Detail, Node033, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.279 Info, Node033, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.279 Info, contrlr, Node 034 - New
2019-08-07 09:30:46.279 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.279 Detail, Node034, QueryStage_ProtocolInfo
2019-08-07 09:30:46.280 Detail, Node034, Queuing (Query) Get Node Protocol Info (Node=34): 0x01, 0x04, 0x00, 0x41, 0x22, 0x98
2019-08-07 09:30:46.280 Detail, Node034, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.280 Info, Node034, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.280 Info, contrlr, Node 036 - New
2019-08-07 09:30:46.280 Detail, Node036, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.280 Detail, Node036, QueryStage_ProtocolInfo
2019-08-07 09:30:46.280 Detail, Node036, Queuing (Query) Get Node Protocol Info (Node=36): 0x01, 0x04, 0x00, 0x41, 0x24, 0x9e
2019-08-07 09:30:46.280 Detail, Node036, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.280 Info, Node036, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.280 Info, contrlr, Node 037 - New
2019-08-07 09:30:46.280 Detail, Node037, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.281 Detail, Node037, QueryStage_ProtocolInfo
2019-08-07 09:30:46.281 Detail, Node037, Queuing (Query) Get Node Protocol Info (Node=37): 0x01, 0x04, 0x00, 0x41, 0x25, 0x9f
2019-08-07 09:30:46.281 Detail, Node037, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.281 Info, Node037, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.281 Info, contrlr, Node 038 - New
2019-08-07 09:30:46.281 Detail, Node038, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-08-07 09:30:46.281 Detail, Node038, QueryStage_ProtocolInfo
2019-08-07 09:30:46.281 Detail, Node038, Queuing (Query) Get Node Protocol Info (Node=38): 0x01, 0x04, 0x00, 0x41, 0x26, 0x9c
2019-08-07 09:30:46.281 Detail, Node038, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.281 Info, Node038, Initializing Node. New Node: false (false)
2019-08-07 09:30:46.282 Detail, Expected reply was received
2019-08-07 09:30:46.282 Detail, Message transaction complete
2019-08-07 09:30:46.282 Detail, contrlr, Removing current message
2019-08-07 09:30:46.282 Detail, Node001, Notification: DriverReady
2019-08-07 09:30:46.285 Detail, Node001, Notification: NodeNew
2019-08-07 09:30:46.286 Detail, Node001, Notification: NodeAdded
2019-08-07 09:30:46.290 Detail, Node003, Notification: NodeNew
2019-08-07 09:30:46.290 Detail, Node003, Notification: NodeAdded
2019-08-07 09:30:46.295 Detail, Node004, Notification: NodeNew
2019-08-07 09:30:46.295 Detail, Node004, Notification: NodeAdded
2019-08-07 09:30:46.299 Detail, Node005, Notification: NodeNew
2019-08-07 09:30:46.300 Detail, Node005, Notification: NodeAdded
2019-08-07 09:30:46.305 Detail, Node007, Notification: NodeNew
2019-08-07 09:30:46.306 Detail, Node007, Notification: NodeAdded
2019-08-07 09:30:46.311 Detail, Node008, Notification: NodeNew
2019-08-07 09:30:46.312 Detail, Node008, Notification: NodeAdded
2019-08-07 09:30:46.316 Detail, Node010, Notification: NodeNew
2019-08-07 09:30:46.317 Detail, Node010, Notification: NodeAdded
2019-08-07 09:30:46.322 Detail, Node012, Notification: NodeNew
2019-08-07 09:30:46.322 Detail, Node012, Notification: NodeAdded
2019-08-07 09:30:46.327 Detail, Node013, Notification: NodeNew
2019-08-07 09:30:46.329 Detail, Node013, Notification: NodeAdded
2019-08-07 09:30:46.335 Detail, Node014, Notification: NodeNew
2019-08-07 09:30:46.335 Detail, Node014, Notification: NodeAdded
2019-08-07 09:30:46.342 Detail, Node015, Notification: NodeNew
2019-08-07 09:30:46.342 Detail, Node015, Notification: NodeAdded
2019-08-07 09:30:46.347 Detail, Node016, Notification: NodeNew
2019-08-07 09:30:46.348 Detail, Node016, Notification: NodeAdded
2019-08-07 09:30:46.353 Detail, Node020, Notification: NodeNew
2019-08-07 09:30:46.354 Detail, Node020, Notification: NodeAdded
2019-08-07 09:30:46.359 Detail, Node021, Notification: NodeNew
2019-08-07 09:30:46.360 Detail, Node021, Notification: NodeAdded
2019-08-07 09:30:46.365 Detail, Node024, Notification: NodeNew
2019-08-07 09:30:46.366 Detail, Node024, Notification: NodeAdded
2019-08-07 09:30:46.372 Detail, Node029, Notification: NodeNew
2019-08-07 09:30:46.373 Detail, Node029, Notification: NodeAdded
2019-08-07 09:30:46.375 Detail, Node030, Notification: NodeNew
2019-08-07 09:30:46.376 Detail, Node030, Notification: NodeAdded
2019-08-07 09:30:46.379 Detail, Node031, Notification: NodeNew
2019-08-07 09:30:46.379 Detail, Node031, Notification: NodeAdded
2019-08-07 09:30:46.382 Detail, Node033, Notification: NodeNew
2019-08-07 09:30:46.383 Detail, Node033, Notification: NodeAdded
2019-08-07 09:30:46.386 Detail, Node034, Notification: NodeNew
2019-08-07 09:30:46.386 Detail, Node034, Notification: NodeAdded
2019-08-07 09:30:46.390 Detail, Node036, Notification: NodeNew
2019-08-07 09:30:46.390 Detail, Node036, Notification: NodeAdded
2019-08-07 09:30:46.393 Detail, Node037, Notification: NodeNew
2019-08-07 09:30:46.394 Detail, Node037, Notification: NodeAdded
2019-08-07 09:30:46.397 Detail, Node038, Notification: NodeNew
2019-08-07 09:30:46.398 Detail, Node038, Notification: NodeAdded
2019-08-07 09:30:46.401 Detail,
2019-08-07 09:30:46.401 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-08-07 09:30:46.404 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x96, 0x0f, 0x64
2019-08-07 09:30:46.404 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2019-08-07 09:30:46.404 Detail, Node015, Expected reply was received
2019-08-07 09:30:46.404 Detail, Node015, Message transaction complete
2019-08-07 09:30:46.404 Detail, contrlr, Removing current message
2019-08-07 09:30:46.404 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-08-07 09:30:46.406 Detail, contrlr, Removing current message
2019-08-07 09:30:46.406 Info, Node001, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=1): 0x01, 0x04, 0x00, 0x41, 0x01, 0xbb
2019-08-07 09:30:46.409 Detail, Node001, Received: 0x01, 0x09, 0x01, 0x41, 0x93, 0x16, 0x01, 0x02, 0x02, 0x01, 0x33
2019-08-07 09:30:46.409 Info, Node001, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2019-08-07 09:30:46.409 Info, Node001, Protocol Info for Node 1:
2019-08-07 09:30:46.409 Info, Node001, Listening = true
2019-08-07 09:30:46.409 Info, Node001, Beaming = true
2019-08-07 09:30:46.409 Info, Node001, Routing = false
2019-08-07 09:30:46.409 Info, Node001, Max Baud Rate = 40000
2019-08-07 09:30:46.409 Info, Node001, Version = 4
2019-08-07 09:30:46.409 Info, Node001, Security = false
2019-08-07 09:30:46.415 Info, Node001, Basic device class (0x02) - Static Controller
2019-08-07 09:30:46.415 Info, Node001, Generic device Class (0x02) - Static Controller
2019-08-07 09:30:46.415 Info, Node001, Specific device class (0x01) - Static PC Controller
2019-08-07 09:30:46.415 Info, Node001, COMMAND_CLASS_BASIC is not mapped
2019-08-07 09:30:46.415 Info, Node001, Mandatory Command Classes for Node 1:
2019-08-07 09:30:46.416 Info, Node001, None
2019-08-07 09:30:46.416 Info, Node001, Mandatory Command Classes controlled by Node 1:
2019-08-07 09:30:46.416 Info, Node001, COMMAND_CLASS_BASIC
2019-08-07 09:30:46.416 Detail, Node022, Expected reply was received
2019-08-07 09:30:46.416 Detail, Node022, Message transaction complete
2019-08-07 09:30:46.416 Detail, Node001, Removing current message
2019-08-07 09:30:46.416 Detail, Node001, Notification: NodeProtocolInfo
2019-08-07 09:30:46.418 Detail, Node001, Notification: ValueAdded
2019-08-07 09:30:46.419 Detail, Node001, Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.419 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2019-08-07 09:30:46.419 Detail, Node001, QueryStage_Probe
2019-08-07 09:30:46.419 Detail, Node001, QueryStage_WakeUp
2019-08-07 09:30:46.419 Detail, Node001, QueryStage_ManufacturerSpecific1
2019-08-07 09:30:46.419 Detail, Node001, Load Controller Manufacturer Specific Config
2019-08-07 09:30:46.460 Info, Product name collision: FGR223 Roller Shutter Controller 3 type 303 id 1000 manufacturerid 10f, collides with FGRM223 Roller Shutter Controller 3, type 303 id 1000 manufacturerid 10f
2019-08-07 09:30:46.468 Info, Node001, Opening config param file /srv/homeassistant/lib/python3.7/site-packages/python_openzwave/ozw_config/aeotec/zw090.xml
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_NodePlusInfo
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_SecurityReport
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_ManufacturerSpecific2
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_Versions
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_Instances
2019-08-07 09:30:46.471 Info, Node001, Essential node queries are complete
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_Static
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_Associations
2019-08-07 09:30:46.471 Detail, Node001, QueryStage_Neighbors
2019-08-07 09:30:46.472 Detail, Requesting routing info (neighbor list) for Node 1
2019-08-07 09:30:46.472 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2019-08-07 09:30:46.472 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2019-08-07 09:30:46.472 Detail, Node001, Notification: EssentialNodeQueriesComplete
2019-08-07 09:30:46.472 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2019-08-07 09:30:46.476 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x9c, 0x7a, 0x88, 0x60, 0x3a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6a
2019-08-07 09:30:46.477 Detail,
2019-08-07 09:30:46.477 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2019-08-07 09:30:46.477 Info, Node001, Neighbors of this node are:
2019-08-07 09:30:46.477 Info, Node001, Node 3
2019-08-07 09:30:46.477 Info, Node001, Node 4
2019-08-07 09:30:46.477 Info, Node001, Node 5
2019-08-07 09:30:46.477 Info, Node001, Node 8
2019-08-07 09:30:46.477 Info, Node001, Node 10
2019-08-07 09:30:46.477 Info, Node001, Node 12
2019-08-07 09:30:46.477 Info, Node001, Node 13
2019-08-07 09:30:46.477 Info, Node001, Node 14
2019-08-07 09:30:46.477 Info, Node001, Node 15
2019-08-07 09:30:46.477 Info, Node001, Node 20
2019-08-07 09:30:46.477 Info, Node001, Node 24
2019-08-07 09:30:46.477 Info, Node001, Node 30
2019-08-07 09:30:46.477 Info, Node001, Node 31
2019-08-07 09:30:46.477 Info, Node001, Node 34
2019-08-07 09:30:46.477 Info, Node001, Node 36
2019-08-07 09:30:46.477 Info, Node001, Node 37
2019-08-07 09:30:46.477 Info, Node001, Node 38
2019-08-07 09:30:46.477 Detail, Node122, Expected reply was received
2019-08-07 09:30:46.477 Detail, Node122, Message transaction complete
2019-08-07 09:30:46.477 Detail, Node001, Removing current message
2019-08-07 09:30:46.478 Detail,
2019-08-07 09:30:46.478 Info, Node003, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=3): 0x01, 0x04, 0x00, 0x41, 0x03, 0xb9
2019-08-07 09:30:46.480 Detail, Node003, Received: 0x01, 0x09, 0x01, 0x41, 0xd3, 0x9c, 0x00, 0x04, 0x10, 0x01, 0xec
2019-08-07 09:30:46.480 Info, Node003, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2019-08-07 09:30:46.480 Info, Node003, Protocol Info for Node 3:
2019-08-07 09:30:46.480 Info, Node003, Listening = true
2019-08-07 09:30:46.480 Info, Node003, Beaming = true
2019-08-07 09:30:46.480 Info, Node003, Routing = true
2019-08-07 09:30:46.480 Info, Node003, Max Baud Rate = 40000
2019-08-07 09:30:46.480 Info, Node003, Version = 4
2019-08-07 09:30:46.480 Info, Node003, Security = false
2019-08-07 09:30:46.480 Info, Node003, Basic device class (0x04) - Routing Slave
2019-08-07 09:30:46.480 Info, Node003, Generic device Class (0x10) - Binary Switch
2019-08-07 09:30:46.480 Info, Node003, Specific device class (0x01) - Binary Power Switch
2019-08-07 09:30:46.480 Info, Node003, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_SWITCH_BINARY
2019-08-07 09:30:46.480 Info, Node003, Mandatory Command Classes for Node 3:
2019-08-07 09:30:46.480 Info, Node003, COMMAND_CLASS_SWITCH_BINARY
2019-08-07 09:30:46.481 Info, Node003, COMMAND_CLASS_SWITCH_ALL
2019-08-07 09:30:46.481 Info, Node003, Mandatory Command Classes controlled by Node 3:
2019-08-07 09:30:46.481 Info, Node003, None
2019-08-07 09:30:46.481 Detail, Node156, Expected reply was received
2019-08-07 09:30:46.481 Detail, Node156, Message transaction complete
2019-08-07 09:30:46.481 Detail, Node003, Removing current message
2019-08-07 09:30:46.481 Detail, Node003, Notification: NodeProtocolInfo
2019-08-07 09:30:46.483 Detail, Node003, Notification: ValueAdded
2019-08-07 09:30:46.486 Detail, Node003, Notification: ValueAdded
2019-08-07 09:30:46.487 Detail, Node003, Query Stage Complete (ProtocolInfo)
2019-08-07 09:30:46.487 Detail, Node003, AdvanceQueries queryPending=0
