Restoring Deleted Dashboard
I recently deleted one of my dashboards by accident and managed to recover it, but realised that there wasn’t much information on how to do it online, so I thought I would share my method.
  1. Download the latest backup you have (core_yyyy.n.n).
  2. Open and expand the tar.gz that will be downloaded.
  3. Locate the following file: .storage/lovelace.lovelace_home - (The .storage folder is hidden so you will need to make sure you set your explorer/finder to show hidden files)
  4. Open the aforementioned file in Notepad (or equivalent app) on your device.
On your home assistant:
Navigate to /config/.storage (I used the terminal/ssh add on to do this)
Open the lovelace.lovelave_home file in your editor of choice (I used vim).
Extract the section of the lovelace.lovelace_home that is missing and insert it into the correct part of the file.
This will be under the data, config, views section (in the below - it would be a view called “House”) 0 this is just the heading part and not the full config for the view).
  "data": {
    "config": {
      "views": [
          "theme": "ios-dark-mode-blue-red",
          "title": "House",
          "path": "house",
I found that if I recreated the dashboard initially (with no cards inside) it helped position in the file.
Then restart.
Note: Be very careful as any errors will prevent all dashboards from showing!
:astonished: :flushed: :sweat: :smiley: nice one!
Thanks this just saved me hours of having to rebuild my dashboard after messing up
Backups are now encrypted, how do you get to the contents?
You can disable encryption, and you can find decryption scripts on the forum.
