ReTerminal E10004
I ordered an Reterminal E10004 several months ago and it finally showed up today.
While waiting for it to arrive I got Puppet setup and used Claude to design a dashboard that I am happy with.
I am now at the point of needing to flash the device to ESPHome and I am completely new to this. I found this thread that is close but I don’t understand the ESPHome YAML.
Can I change E1002 to E1004 and flash it? with the ESP Flasher is there a risk of bricking the device?
Will I have the ability to refresh the display in Home Assistant?
Can I change the URL from Puppet in Home Assistant?
I don’t have a E1004, but the process should be basically the same as the E1002. Take a look at the following link. It does say the E1004 is supported. It looks like it should be the same (or similar) to the E1002.
I’d start there and get a basic example working and then try to add Puppet logic in.
Finally got around to working on this and have this YAML. The display is loading the screenshot from Puppet and everything seems to be working. I plan on adjusting the frequency of screen refreshes and adding a URL with pictures for certain times of the day in the future.
# reTerminal E1004 — ESPHome Full Hardware Example
# All onboard peripherals enabled in the most basic way
# Converted from a reTerminal E1002 config. Key hardware differences vs E1002:
#   - Display: 13.3" full-color E Ink Spectra 6, 1200x1600 (portrait), vs
#     E1002's 7.3" 800x480. Same 6-color palette (BLACK/WHITE/RED/GREEN/
#     BLUE/YELLOW). Model string is "Seeed-reTerminal-E1004".
#   - Frame buffer for this panel is ~960KB, which does NOT fit in the
#     ESP32-S3's internal SRAM, so the `psram:` component is now REQUIRED
#     (it was not strictly needed for the smaller E1002 buffer).
#   - Onboard LED moved from GPIO6 -> GPIO48 (inverted, LOW = on).
#   - No onboard microphone on E1004 (E1002/E1003 have one "reserved";
#     E1004 does not). i2s_audio / microphone / mic power-enable removed.
#   - Buttons, buzzer, battery ADC/enable, SD card pins, I2C bus (SHT4x +
#     PCF8563 RTC) and the deep-sleep wake pin are all on the same GPIOs
#     as the E1002 per Seeed's reTerminal E-series documentation. Physical
#     silkscreen labels differ (E1004 has front nav/refresh buttons instead
#     of green/white buttons) — verify against your unit if behavior seems
#     swapped.
#   - Display content is now a remote pre-rendered image (see http_request /
#     image: online_image below) instead of a locally hand-drawn dashboard.
#     Onboard sensors (temp/humidity/battery/SD detect) are still exposed
#     to Home Assistant, just no longer drawn on screen.
# Hardware list:
#   1. 13.3" COLOR ePaper display (1200x1600, SPI)
#      Supported colors: BLACK, WHITE, RED, GREEN, BLUE, YELLOW
#   2. 3x buttons (GPIO3, GPIO4, GPIO5)
#   3. Buzzer (GPIO45, PWM)
#   4. Onboard LED (GPIO48)
#   5. Battery voltage (GPIO1 ADC + GPIO21 EN)
#   6. SHT4x temp & humidity sensor (I2C)
#   7. PCF8563 RTC (I2C addr 0x51, CR1220 backup)
#   8. MicroSD card slot (SPI + DET=15, EN=16)
#   9. Deep sleep with button wake-up
# NOTE: Requires ESPHome >= 2025.11.1 for epaper_spi platform
# Serial debug: UART0 via CH340K USB bridge
substitutions:
  device_name: reterminal-e1004
  friendly_name: "reTerminal_E1004"
esphome:
  friendly_name: ${friendly_name}
  on_boot:
    priority: 600
    then:
      # Turn on SD card power rail
      - output.turn_on: bsp_sd_enable
      # Turn on battery measurement circuit
      - output.turn_on: bsp_battery_enable
      # Wait for voltages to stabilize
      - delay: 200ms
      # Take first battery reading
      - component.update: battery_voltage
      - component.update: battery_level
      # Read RTC time on boot
      - pcf8563.read_time:
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Required: the 1200x1600 6-color frame buffer (~960KB) does not fit in
# internal SRAM and must live in PSRAM.
psram:
  mode: octal
  speed: 80MHz
# Enable serial logging
# The reTerminal E series has a CH340K USB-to-UART bridge on UART0.
# Default ESP32-S3 logger uses USB_CDC — won't produce output on the physical port.
logger:
  hardware_uart: UART0
# Fonts
font:
  - file: "gfonts://Inter@700"
# SPI — shared by ePaper display and SD card
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO9
  # MISO is needed for SD card reading (ePaper is write-only)
  miso_pin: GPIO8
# I2C — shared by SHT4x sensor, PCF8563 RTC
i2c:
  scl: GPIO20
  sda: GPIO19
output:
  # [4] Onboard LED (active low)
  # NOTE: GPIO48 on E1004, was GPIO6 on E1002
  - platform: gpio
    pin: GPIO48
    inverted: true
  # [8] SD card power enable
  - platform: gpio
    pin: GPIO16
  # [5] Battery measurement enable
  - platform: gpio
    pin: GPIO21
  # [3] Buzzer PWM output
  # 'ledc' is ESP32 hardware PWM
  - platform: ledc
    pin: GPIO45
    frequency: 1000Hz
  # --- SHT4x temperature & humidity (I2C) ---
  - platform: sht4x
    temperature:
    humidity:
      name: "Relative Humidity"
    update_interval: 60s
  # --- Battery voltage (ADC on GPIO1) ---
  - platform: adc
    pin: GPIO1
    attenuation: 12db
    filters:
      # Compensate for onboard voltage divider (1:2)
      - multiply: 2.0
  # --- Battery level (percentage) ---
    unit_of_measurement: "%"
    icon: "mdi:battery"
    device_class: battery
    state_class: measurement
    lambda: 'return id(battery_voltage).state;'
    filters:
      - calibrate_linear:
          - 4.15 -> 100.0
          - 3.96 -> 90.0
          - 3.91 -> 80.0
          - 3.85 -> 70.0
          - 3.80 -> 60.0
          - 3.75 -> 50.0
          - 3.68 -> 40.0
          - 3.58 -> 30.0
          - 3.49 -> 20.0
          - 3.41 -> 10.0
          - 3.30 -> 5.0
          - 3.27 -> 0.0
      - clamp:
          min_value: 0
          max_value: 100
binary_sensor:
  # Button 1 (GPIO3) — flash LED + short beep
  - platform: gpio
    pin:
      number: GPIO3
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - logger.log: "Button 1 pressed - flash LED + beep"
        - light.turn_on: onboard_led
        - light.turn_on:
            brightness: 50%
        - delay: 200ms
        - light.turn_off: buzzer
        - light.turn_off: onboard_led
  # Button 2 (GPIO4) — deep sleep wake-up button
  # Button 3 (GPIO5) — toggle LED on/off
  - platform: gpio
    pin:
      number: GPIO5
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - logger.log: "Button 3 pressed - toggle LED"
        - light.toggle: onboard_led
  # [8] SD card detect (LOW = card present)
  # NOTE on SD card in ESPHome:
  # ESPHome cannot directly access the SD card file system (read/write files,
  # create directories, etc.) the way Arduino can. In ESPHome, the SD card is
  # used indirectly by specific components:
  #   - online_image: caches downloaded images to SD card
  #   - media_player: plays audio files stored on the card
  #   - Works with PSRAM for large buffer allocation
  # For direct file operations (e.g. recording WAV files), use the Arduino framework.
  - platform: gpio
    pin:
      number: GPIO15
      mode: INPUT_PULLUP
      inverted: true
    name: "SD Card Detected"
light:
  - platform: binary
    output: bsp_led
  # Buzzer wrapped as a "light": brightness = volume
  - platform: monochromatic
    output: buzzer_pwm
    default_transition_length: 0s
time:
  # PCF8563 is at I2C address 0x51 with a CR1220 coin cell backup.
  # On boot we read the RTC; when HA syncs, we write back to the RTC.
  - platform: pcf8563
    address: 0x51
    # No periodic re-reads needed; HA sync handles it
    update_interval: never
  - platform: homeassistant
    # When HA pushes a time sync, write it to the hardware RTC
    on_time_sync:
      then:
        - pcf8563.write_time:
# Home Assistant native API
api:
  encryption:
    key: !secret api_encryption_key
# OTA (Over-The-Air) firmware update
ota:
  - platform: esphome
    password: !secret ota_password
# Wi-Fi settings
wifi:
  ssid: "Goatboy's Network"
  password: "pott8759"
  ap:
    ssid: "reTerminal-E1004"
    password: "ChangeMe123"
  # online_image does NOT auto-download just because a url: is configured —
  # it needs an explicit trigger. Fire it once Wi-Fi is up (http_request
  # needs network anyway) so the image is fetched every wake cycle.
  on_connect:
    then:
      - component.update: dashboard_image
captive_portal:
# Remote dashboard image
# Fetches a pre-rendered PNG/JPEG/BMP from a local server and draws it full
# screen. Server URL already requests the exact panel resolution (1200x1600)
# and an e-ink-friendly color theme, so no local sensor drawing is needed.
http_request:
  timeout: 20s
  # Cold Wi-Fi connections can block the loop long enough to trip the
  # ESP-IDF task watchdog (observed: crash ~5s into the very first request
  # after connecting). This gives the HTTP request room to run without a
  # spurious reboot.
  watchdog_timeout: 25s
image:
  - platform: online_image
    url: "http://192.168.1.30:10000/eink-test/eink?viewport=1200x1600&theme=E-ink+Warm&zoom=.87&lang=en"
    format: PNG
    type: RGB565
    resize: "1200x1600"
    on_download_finished:
      - component.update: epaper_display
    on_error:
      - logger.log:
          tag: "dashboard_image"
          format: "Failed to download dashboard image"
          level: ERROR
      - globals.set:
          value: "true"
globals:
  - id: dashboard_download_failed
    type: bool
    restore_value: no
    initial_value: "false"
# [1] ePaper display (13.3" COLOR, 1200x1600, portrait)
# Requires ESPHome >= 2025.11.1
# Full refresh takes ~20s (per Seeed spec) — keep deep_sleep run_duration
# comfortably above this.
display:
  - platform: epaper_spi
    model: Seeed-reTerminal-E1004
    # Do NOT auto-render on a timer. The panel transfer takes 20-40s+, and if
    # it were still running when the image finishes downloading, the second
    # component.update() call collides with the first ("Display already in
    # state TRANSFER_DATA"), which was corrupting the driver and crashing the
    # task watchdog. Only ever redraw explicitly, once per wake cycle, after
    # the download succeeds or fails (see image: on_download_finished /
    # on_error above).
    lambda: |-
      const auto BLACK = Color(0, 0, 0, 0);
      if (id(dashboard_download_failed)) {
        it.printf(600, 800, id(font_medium), BLACK, TextAlign::CENTER,
                  "Dashboard download failed");
      } else if (id(dashboard_image).get_width() > 0) {
        it.image(0, 0, id(dashboard_image));
      } else {
                  "Loading dashboard...");
# [9] Deep sleep
# The device wakes for run_duration, updates sensors & display, then sleeps.
# Press the button on GPIO4 to wake manually at any time.
# Color ePaper full refresh takes ~20s — run_duration must exceed that.
deep_sleep:
  run_duration: 150s
  sleep_duration: 12h
  # ESP32-S3 only supports ext1 wakeup (ext0 not available)
  esp32_ext1_wakeup:
    pins:
      - number: GPIO4
        mode: INPUT_PULLUP
    mode: ANY_LOW
# secrets.yaml (create this file alongside your config):
# wifi_ssid: "Your WiFi SSID"
# wifi_password: "Your WiFi Password"
# ota_password: "choose-a-strong-password"
# api_encryption_key: "generate with: openssl rand -base64 32"
This is a very nice looking dashboard. Would you mind sharing the yaml for the dashboard?
Do you mean my dashboard? I can share the yaml but if I’m remembering there’s a custom theme also.
Yes. Or maybe just some hints on how you did the nice large date and current weather on the top
