I was trying to get the readings of the Broadlink S1C door and motion sensors, with the MQTT/Python method. Was not really able to figure it out, so I found an alternative way. It works pretty good.
Required:
- Always running Android (in the same LAN)
- Tasker App
- RM Plugin App (HTTP Bridge)
Optional: - Joaoapps autotools (JSON reader)
- Joaoapps join (send tasker task)
The RM Plugin HTTP bridge outputs a Json API at: androidIP/s1_status?deviceMac=S1c:MAC:Address
You can use Tasker to retrieve and split the JSON data, but I use Autotools to make it easier. You could probably do this directly in HASS, but Iām not that skilled yet.
Then you can send a HTTP post directly to HASS and the sensors are available.
