Hi
I would like to retrieve the consumed kwh per hour from the energy panel and use that in a template sensor. Is that possible?
BR/Nicklas
Hi
BR/Nicklas
Hello Nylund,
Do you have a Smart Meter in your home or anything that currently displays this value?
There are several options you can try/use but it does depend on what is available to you. If you’re in the UK and have a SMET2 Smart Meter I’d say the best route would be using the ‘Bright App’ and custom integration (Hildebrand Glow (DCC)).
Yes, I get all the data so I can probably use a utility meter or something else to collect the consumed energy per hour but it would be nice to use the data from the energy panel since it is already there…
Okay, great.
So are these values coming from a Smart Meter? If so how are you viewing them, on an IHD?
Where about are you Geographically, as I mentioned there is the ‘Bright’ app which will work well but this will not work outside of the UK. But there may be alternatives which can be suggested.
No, probably not because that is for a different solution called the same
But I already get the data in to home assistant via esphome. It is the 1h accumulated energy consumtion I want.
