Retrieve the target friendly name in a template
Hi guys,
I wrote a simple automation to get the friendly name of a target. However, I haven’t been lucky with that. Here it is:
alias: test
description: ""
  - platform: time
    at: "08:30:55"
condition: []
  - action: switch.toggle
    metadata: {}
    data: {}
      entity_id: switch.tapo_smart_plug
  - action: notify.mobile_app_ebiscaia_s_11pro
    metadata: {}
      message: >-
        the device {{ state_attr(entity_id, 'friendly_name') }} was
        triggered
mode: single
The automation is not triggered in this case:
Template variable error: ‘entity_id’ is undefined when rendering ‘the device {{ state_attr(entity_id, ‘friendly_name’) }} was triggered’
And other attempts were (with no success and similar error messages):
target.entity_id
hi!
i think you have a misunderstanding of variables. in the switch.toggle call, your line that says:
only defines the entity_id for the call to switch.toggle. it does not define it for your whole automation.
in your particular example, there doesn’t seem to be a reason to use that entity_id… so you can just do:
       the device {{ state_attr('switch.tapo_smart_plug', 'friendly_name') }} was
but i’m guessing there’s a different use case where you may want it calculated or passed in? if so, show that code and we may be able to help solve that situation.
Thanks for your reply. Here is the automation I am trying to get proper notifications (do not consider the message blocks because it is where I need to fix):
alias: Plant light trigger
description: ""
  - platform: sun
    event: sunrise
    offset: "-1:00:00"
  - platform: sun
    event: sunrise
    offset: "3600"
  - platform: sun
    event: sunset
    offset: "3600"
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - sunrise1
        sequence:
          - metadata: {}
            data: {}
            action: switch.turn_on
              entity_id: switch.sunshine_for_plants_socket_1
          - data:
              title: Automation "Plant light trigger" executed
              message: The device(s) was(were) turned on
      - conditions:
            id:
              - sunset2
        sequence:
          - metadata: {}
            data: {}
          - metadata: {}
              message: The device(s) {{ trigger.entity_id }} was(were)     turned on
              title: Automation triggered
      - conditions:
            id:
              - sunset
        sequence:
          - metadata: {}
            data: {}
            action: switch.turn_off
              entity_id:
                - switch.sunshine_for_plants_socket_1
                - switch.tapo_smart_plug
          - data:
              message: >-
                The device(s) {{ state_attr('target.entity_id', 'friendly_name')
                }} was(were) turned off
            enabled: true
mode: single
My idea is to use templates so that I can call the right name(s) without hard-coding the entities so that I could expand it in the future.
you could do something like this, but i don’t think it wins you anything.
description: ""
  - platform: sun
    event: sunrise
    offset: "-1:00:00"
  - platform: sun
    event: sunrise
    offset: "3600"
  - platform: sun
    event: sunset
    offset: "3600"
condition: []
  - variables:
      use_entity: |
        {% if trigger == 'sunrise1' %}
        {% elif trigger == 'sunset2' %}
        {% elif trigger == 'sunset' %|
          switch.sunshine_for_plants_socket_1, switch.tapo_smart_plug
        {% endif %}
  - choose:
      - conditions:
            id:
              - sunrise1
        sequence:
          - metadata: {}
            data: {}
              entity_id: >
                {{ use_entity }}
          - data:
      - conditions:
            id:
              - sunset2
        sequence:
          - metadata: {}
            data: {}
              entity_id:
                {{ use_entity }}
          - metadata: {}
      - conditions:
            id:
              - sunset
        sequence:
          - metadata: {}
            data: {}
              entity_id:
                {{ use_entity }}
          - data:
              message: >-
            enabled: true
mode: single
you could also add the entity_id(s) to use in a trigger variable. I also included the action to take, to even simplify it a bit more.
description: ""
  - platform: sun
    event: sunrise
    offset: "-1:00:00"
    variables:
      action: "on"
      to_toggle:
  - platform: sun
    event: sunrise
    offset: "3600"
    variables:
      action: "on"
      to_toggle:
  - platform: sun
    event: sunset
    offset: "3600"
    variables:
      action: "off"
      to_toggle:
  - action: switch.turn_{{ action }}
      entity_id: "{{ to_toggle }}"
      message: The {{ to_toggle | map('state_attr', 'friendly_name') | join(' and ') }}  {{ 'was' if to_toggle | count ==  1 else 'were' }} turned {{ action }}
mode: single
ah yes! @TheFes 's answer is better! i didn’t notice that the triggers mapped to the conditions one for one.
