Retry network storage after failure
The network storage feature should be configurable to automatically attempt to reconnect after a connection failure. Currently, if the network storage is unavailable when HA starts, the network storage is not mounted until a user manually clicks the repair item.
The use case of this is in the event of a power outage. My HA device finishes booting before my NAS is fully online, so the network storage doesn’t mount until I manually intervene.
Anyone have a solution to force the network storage reconnect? :smiling_face_with_tear:
Same problem here, it would be interesting to know if this feature is in development, even though I do not think so, since I did not find any issue about that on GitHub
Same problem here
Did you find a solution? My NAS goes to sleep (intentionally) and once this happens, HA starts to complain and alarm notifications start popping up. Would like to have the possibility to connect to NAS only for the backup purposes.
Perhaps even better periodical backups NAS, other backups staying on HA
@liberson I use the “Rclone backup” add-on for this!
This is supposed to be fixed Network storage: Re-establishing the connection without restarting HomeAssistant · Issue #4662 · home-assistant/supervisor · GitHub, but mine never reconnects not even when I click reload in the repair notification
