I’ve been playing about with a Shelly Plus 1 inside a wall switch that drives a zigbee smart light. I’ve been trying to cover all bases so if the smart light is available (through HA), the wall switch toggles the smart light, but if for some reason HA or the zigbee network is down, the light can still be toggled because the wall switch then drives the Shelly relay.
I can detect if the HA API is connected, but this doesn’t tell me if the Zigbee network is connected. Is there a way to pull the status of the Zigbee bulb from Home Assistant into ESPHome?
I’m assuming this would be done using some kind of Lambda function, but this is my first attempt using them and I’ve hit a brick wall so far.
My Shelly yaml (without anything to detect the Zigbee status) is here (it’s a bit of a monster):
substitutions:
# Nice name
device_name: "Office Light Shelly Plus 1"
# Unique name for the device
# Name of entity to be controlled by this device
target_entity: "light.office_light"
# Static IP Address for the device
static_ip: "192.168.0.225"
# Higher value gives lower watt readout
current_res: "0.001"
# Lower value gives lower voltage readout
voltage_div: "1925"
esphome:
platformio_options:
board_build.f_cpu: 160000000L
esp32:
board: esp32doit-devkit-v1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_FREERTOS_UNICORE: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_160: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ: "160"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: ${static_ip}
gateway: 192.168.0.1
subnet: 255.255.255.0
ap:
ssid: "Shelly Office Fallback Hotspot"
password: !secret ap_password
logger:
api:
encryption:
key: !secret api_encryption_key
ota:
password: !secret ota_password
# Enable Web server (optional).
web_server:
port: 80
# Shelly 1 detached switch config with fallback in case of wifi or api fail
output:
- platform: gpio
pin: GPIO26
switch:
- platform: output
output: "relay_output"
# after reboot, keep the relay off. this prevents light turning on after a power outage
restore_mode: ALWAYS_OFF
binary_sensor:
- platform: gpio
pin:
number: GPIO4
# small delay to prevent debouncing
filters:
- delayed_on_off: 50ms
# config for state change of input toggle
# Case 1: Can't connect to home assistant. Relay is off so smart bulb must be off and state change was off - do nothing
# Case 2: Can't connect to home assistant. Relay is off so smart bulb must be off and state change was on - turn on relay
# Case 3: Can't connect to home assistant, Relay is on so smart bulb is powered but state is unknown, and state change was off - turn off relay
# Case 4: Can't connect to home assistant, Relay is on so the smart bulb is powered but state is unknown, and state change was to on - Turn off relay then turn it on
# Case 5: API is connected, relay is off so smart bulb must be off. State change was to off - do nothing. This is problematic as it means the API is connected but the smart bulb still can't be controlled using home assistant
# Case 6: API is connected, relay is off so smart bulb must be off. State change was to on - turn on relay
# Case 7: API is connected, relay is on so smart bulb is powered but state is unknown. State change was to off - tell home assistant to turn off smart bulb
# Case 8: API is connected, relay is on so smart bulb is powered but state is unknown. State change was to on - tell home assistant to turn on smart bulb
on_state:
then:
- if:
condition:
- api.connected:
then:
# API is connected so we can talk to Homeassistant
- logger.log: API is connected!
- if:
condition:
- switch.is_on: shelly_relay
then:
- if:
condition:
- binary_sensor.is_on: toggle
then:
- logger.log: Switch was turned on
- homeassistant.service:
service: light.turn_on
entity_id: ${target_entity}
- logger.log: Case 8 - Light was turned on
else:
- logger.log: Switch was turned off
service: light.turn_off
- logger.log: Case 7 - Light was turned off
else:
- if:
condition:
then:
- switch.turn_on: shelly_relay
- logger.log: Case 6 - Relay was turned on
else:
- logger.log: Case 5 - Relay was already turned off
else:
- if:
condition:
then:
- if:
condition:
then:
- switch.turn_off: shelly_relay
- delay: 0.2s
- logger.log: Case 4 - Relay was cycled on
else:
- logger.log: Switch as turned off
- logger.log: Case 3 - Relay was turned off
else:
- if:
condition:
then:
- logger.log: Case 2 - Relay was turned on
else:
- logger.log: Case 1 - Relay was already off
- platform: ntc
sensor: temp_resistance_reading
name: "${device_name} Temperature"
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
on_value_range:
- above: "80.0"
then:
- switch.turn_off: "shelly_relay"
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 10kOhm
- platform: adc
pin: GPIO32
attenuation: 11db
- platform: adc
name: "${device_name} Relay Supply Voltage"
pin: GPIO33
attenuation: 11db
filters:
- multiply: 8
status_led:
pin:
number: GPIO0
inverted: true
