Return previous state thermostat
Hi, can you help me with the automation of the previous state?
I have set the solar panels, if it produces more than 1500W, it will change from the original set temperature to 30 ° C, if the condition is not met, I need the temperature to return to the previous temperature, which was not 30 ° C. Is it real?
- id: '1641466436500'
  alias: Akumulace do podlahy
  description: ''
  - platform: numeric_state
    entity_id: sensor.nadvyroba
    above: '1500'
    for:
      hours: 0
      minutes: 0
      seconds: 10
  condition: []
  - service: climate.set_temperature
      entity_id: climate.temperature_livin_g_room
      temperature: 30
  mode: single
Try a python script as a service, see another post
Noob Question to create custom state - #2 by vingerha)
I think it might be easier to copy the state to an input number and save it that way.
service: input_number.set_value
  entity_id: input_number.previous_target_temperature
  value: "{{ state_attr('climate.temperature_livin_g_room', 'temperature') }}"
To restore it:
  temperature: "{{ states('input_number.previous_target_temperature') }}"
Or you can use dynamically created scenes. However, I don’t think that is a good solution because the scene would not survive a restart of Home Asssiant.
Thanks for the advice, unfortunately it probably won’t help. The problem is that the condition is checked often, so in half an hour the temperature is set again and then stays there as the previous value of 30 ° C. :-/
Climate responds to more resources and controls. Couldn’t just pressing the +/- button be identified?
You should be able to do something like this
  temperature: "{{ state_attr('climate.temperature_livin_g_room', 'temperature') | float + 1.0 }}"
to increase the temperature by 1.0 °C. It might even work without | float, as I’d expect the attribute to be a float value already.
