Hi, I am automating my lounge curtains using a couple of stepper motors. All is going well except for the case when I remove the power from the esp32 which is the controller(using esphome). When the power is restored the stepper doesn’t remember it’s position.
I’ve worked out I can call a service and set the target value back to what it was and all is okay then.
I’m just struggling to get the last good value from history. I guess I’d like to say, get me the last 24hours history of the entity, where the value is numeric and order it by most recent first and select the top 1.
Is the best way to do this a history node and a function node, iterating through the array?
Thanks in advance.
Just restore the last state from flash in the ESP32.
Thank you for replying. I’m struggling to find the option, I can see the option if the platform was the ESP8266, but my platform is the ESP32, do you know if it is possible to do the same with this platform? Thanks
What component do you want to restore?
E.g. template number component:
https://esphome.io/components/number/template.html#configuration-variables
Thanks again for helping Tom. I thought I’d better paste in the code from my device. I have two steppers, two stepper drivers (a4988) and one esp32. I’m trying to restore each of the stepper positions.
I’ve just tried to add the number near the top to hold the rightcurtainposition which is the thing I want restoring when the power comes back on. However, the code failed to compile saying something like it was out of scope.
esphome:
esp32:
board: esp32dev
framework:
type: arduino
number:
restore_value: yes
initial_value: 0.0
step: 1
min_value: -4500
max_value: 0
optimistic: yes
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-0Ec490"
password: ""
captive_portal:
# Enable logging
logger:
ota:
web_server:
port: 80
# Enable Home Assistant API
api:
services:
- service: control_rightcurtain
variables:
target: int
then:
- stepper.report_position:
position: !lambda 'return rightcurtainposition;'
- stepper.set_target:
target: !lambda 'return rightcurtainposition;'
- sensor.template.publish:
state: !lambda 'return rightcurtainposition;'
- service: control_leftcurtain
variables:
target: int
then:
position: !lambda 'return target;'
target: !lambda 'return target;'
state: !lambda 'return target;'
cover:
name: "My Right Curtain"
device_class: curtain
has_position: true
open_action:
target: 0
state: !lambda return id(rightcurtain).target_position;
close_action:
target: -4500
stop_action:
target: !lambda return id(rightcurtain).current_position;
state: !lambda return id(rightcurtain).current_position;
optimistic: true
assumed_state: true
name: "My Left Curtain"
has_position: true
open_action:
target: 0
state: !lambda return id(leftcurtain).target_position;
close_action:
target: -4500
stop_action:
target: !lambda return id(leftcurtain).current_position;
state: !lambda return id(leftcurtain).current_position;
optimistic: true
assumed_state: true
name: "My Right Curtain Position"
name: "My Left Curtain Position"
stepper:
- platform: a4988
step_pin: 21
dir_pin: 22
sleep_pin: 23
max_speed: 250 steps/s
- platform: a4988
step_pin: 17
dir_pin: 18
sleep_pin: 19
There’s an example here of saving and restoring a stepper position:
Thanks Tom I’ll take a look at that now.
Thanks again Tom for the link to the example. By following that I have managed to get it working.
Here’s my code in case anyone finds it useful
esphome:
on_boot:
- priority: -200.0
then:
- logger.log:
format: "Calling on boot Right Position %d"
args: [ 'id(g_rightCurtainPosition)' ]
- stepper.report_position: # Set stepper to global variable
position: !lambda return id(g_rightCurtainPosition);
- stepper.set_target: # Set stepper to global variable
target: !lambda return id(g_rightCurtainPosition);
- cover.template.publish:
state: !lambda return id(g_rightCurtainPosition);
esp32:
board: esp32dev
framework:
type: arduino
globals:
- id: g_rightCurtainPosition
type: int
restore_value: True
initial_value: '0'
- id: g_leftCurtainPosition
type: int
restore_value: True
initial_value: '0'
wifi:
ap:
password: ""
captive_portal:
# Enable logging
logger:
ota:
web_server:
port: 80
api:
services:
variables:
target: int
then:
position: !lambda 'return id(g_rightCurtainPosition);'
target: !lambda 'return id(g_rightCurtainPosition);'
state: !lambda 'return id(rightCurtainStepper).current_position;'
- globals.set:
value: !lambda return id(rightCurtainStepper).current_position;
variables:
target: int
then:
position: !lambda 'return id(leftCurtainStepper).current_position;'
target: !lambda 'return id(g_leftCurtainPosition);'
state: !lambda 'return id(leftCurtainStepper).current_position;'
cover:
open_action:
- logger.log: "Opening"
target: 0
state: !lambda return id(rightCurtainStepper).target_position;
- globals.set:
value: !lambda return id(rightCurtainStepper).target_position;
close_action:
target: -4500
- globals.set:
stop_action:
target: !lambda return id(rightCurtainStepper).current_position;
state: !lambda return id(rightCurtainStepper).current_position;
- globals.set:
optimistic: true
assumed_state: true
has_position: true
open_action:
target: 0
state: !lambda return id(leftCurtainStepper).target_position;
close_action:
target: -4500
stop_action:
target: !lambda return id(leftCurtainStepper).current_position;
state: !lambda return id(leftCurtainStepper).current_position;
optimistic: true
assumed_state: true
stepper:
- platform: a4988
step_pin: 21
dir_pin: 22
sleep_pin: 23
- platform: a4988
step_pin: 17
dir_pin: 18
sleep_pin: 19
