I’m trying to make my security system smarter with Home-Assistant.
I’m trying to achieve the following: when the security system is armed in home mode (stay or night), the humidity in the bathroom is above a threshold, and the window is opened, do not trigger the alarm.
Some information on my system:
- I have a group of binary sensors for outside contacts (all windows and doors that can be an entry/exit point)
- I have a group of binary sensors for inside contacts (all windows and doors that do not represent interaction with the outside world; those are used when armed away)
- I have motion, temperature, and humidity sensors in the bathrooms
- I have a virtual sensor (input_number) where I set the threshold for humidity in the bathroom
- I have a virtual sensor for the number of contacts that have been in an open state at the moment of arming
- I have a virtual sensor for the names of contacts that have been in an open state at the moment of arming
- I have a virtual sensor that stores the diff between the number of contacts that are now open vs the number of open contacts at the moment of arm
- I have automation in place, so when I close contact while armed, I get alerts/notifications and reset virtual sensors as I am arming
- I have automation that, if it determines that a new contact has opened, will trigger an alarm
- I have a macro function that can tell me the friendly name of the contact that was opened or closed in such a case (this may be a hack, but in my limited knowledge of the platform, I do not know of another solution where things are dynamically configured) it is a string separated by “;” where at index 0 I get true/false if there was an error, at index 1 I get the error message, at index 2 I get the opened contact name and at index 3 I get the closed contact name
Now, my problem is that my automation looks like this:
alias: "security: trigger-alarm-stay"
description: ""
- platform: state
entity_id:
- sensor.alarm_new_door_opened
to: "1"
condition:
- condition: or
conditions:
- condition: state
entity_id: alarm_control_panel.home_alarm
state: armed_home
enabled: true
- condition: state
state: armed_night
enabled: true
- condition: state
state: armed_away
enabled: true
- if:
- condition: template
value_template: >-
{# check that the opened contact is 1.BS window #}
{% from 'contact_sensor_changes.jinja' import contact_sensor_changes
{% set result = contact_sensor_changes(true, true)|trim %}
{% set result = result.split(';') %}
{{ result[2] == state_attr('binary_sensor.1_bs_window_contact',
'friendly_name') }}
- condition: numeric_state
entity_id: sensor.1_bs_aerq_relative_humidity_measurement
above: input_number.humidity_bathroom_threshold
- condition: state
entity_id: binary_sensor.1_bs_window_contact
state: "on"
then:
- parallel:
- service: notify.mobile_phones
title: "security-system: opened contact"
message: >-
contact_sensor_changes %} {% set result =
contact_sensor_changes(true, true)|trim %} {% set result =
result.split(';') %} {% if result[2] %}
Opened contact is {{ result[2] }}, skipped alarm trigger as the humidity is above thredshold.
{% elif result[0]=='True' %}
There was an error trying to determine opened contact -> {{ result[1] }}
{% endif %}
- service: script.alarm_reset_helpers
data: {}
else:
- if:
value_template: >-
{# check that the opened contact is 0.BJ window #}
{{ result[2] == state_attr('binary_sensor.0_bj_window_contact',
'friendly_name') }}
entity_id: sensor.0_bj_aerq_relative_humidity_measurement
- condition: state
entity_id: binary_sensor.0_bj_window_contact
state: "on"
then:
- parallel:
message: >-
{% endif %}
data: {}
else:
- parallel:
title: "security-system: alarm trigger"
message: >-
result.split(';') %} A door/window has been opened, open
contacts are {{ states('sensor.info_open_doors') }}. {% if
result[2] %}
There was an error trying to determine closed contact -> {{ result[1] }}
{% endif %}
- service: alarm_control_panel.alarm_trigger
data: {}
enabled: true
mode: single
Notice how many times I have the same part of the template…
Is there any way to put the result of the macro in a variable (multiple variables) and use them in my automation?
