Hi
I created at custom constrain, but I’ve like to use it across different Appdaemon Apps/Classes. Is there a dynamic way to register a constraint? I tried using a second Class, but keep getting error. If not, what the best Pythonway to reuse the function?
And second, Globals parameters in App daemon? I’m using the time constrain, it would be nice if I only had to set the time period one place.
/Lars
if "constrain_list" in self.args:
self.register_constraint("custom_constrain_multi")
self.listen_event(self.start_preset, custom_constrain_multi=self.args["constrain_list"],
event="MQTT_MESSAGE", namespace="mqtt", topic="home/preset/"+self.topic, payload="on")
else:
self.listen_event(self.start_preset, event="MQTT_MESSAGE", namespace="mqtt",
I’m not sure if this works, but you could try creating an app for your custom constraints, like my_constraints.py and then import the constrain from this app whenever you want to use it with:
from my_constraints import custom_constrain_multi
You’d need to try it, but I think this should work.
I can’t find a working combo. I’m still stuck on how to parse the custom constraint.
AttributeError: ‘Test’ object has no attribute ‘custom_constraint_multi’
test.py
I been using my test Class and trying the different imports etc,
import hassapi as hass
import mqttapi as mqtt
from include import utils
from include import constraints
#from include.constraints import CustomConstrains
class Test(mqtt.Mqtt, hass.Hass):
def initialize(self):
self.convert = utils.Converter()
self.register_constraint("custom_constraint_multi")
self.listen_event(self._deconz_event,"deconz_event", id="kon_swi_bord02",
custom_constraint_multi=self.args["constrain_list"])
self.listen_event(self._deconz_event, event="MQTT_MESSAGE",
namespace="mqtt", topic="home/preset/test",
Constraints.py
class CustomConstraints(hass.Hass):
def custom_constrain_multi(self, constrain_list):
list_true = []
list_false = []
for item in constrain_list:
try:
entity = self.split_device_list(item)[0]
action = self.split_device_list(item)[1]
if action.lower() in ("true","on"):
list_true.append(entity)
elif action.lower() in ("false", "off"):
entity_state = self.convert.str2bool(self.get_state(entity))
self.log("Get False State %s (%s)" % (entity,entity_state))
list_false.append(entity_state)
except IndexError:
self.error("Failed to sort %s" % item)
self.log("%s vs %s" % (self.custom_constrain_list(list_true),all(e == False for e in list_false)))
if self.custom_constrain_list(list_true) and all(e == False for e in list_false):
return True
else:
return False
def custom_constrain_list(self, entity_list):
condition_list = []
for item in entity_list:
self._verbose("Get State %s (%s)" % (item,self.get_state(item, attribute="state")))
condition_list.append(
if all(condition_list):
return True
else:
return False
Sorry, I didn’t mention constraint.py was in separate directory “include”. I moved constraint.py into same directory as test.py and trimmed test.py down to the basic and still get the same error.
File "/appdaemon/lib/python3.7/site-packages/appdaemon/threading.py", line 552, in check_constraint
method = getattr(app, key)
AttributeError: 'Test' object has no attribute 'custom_constraint_multi'
test.py
from constraints import CustomConstraints
class Test(hass.Hass):
def _deconz_event(self, deconz_event, deconz_entity, kwargs):
light = "light.kon_loftlys"
self.toggle(light)
If I try to import function direcly i get import error.
from constraints import custom_constrain_multi
ImportError: cannot import name 'custom_constrain_multi' from 'constraints' (/appdaemon/conf/apps/test/constraints.py)
I’m parsing boolean and sensors in constrain_list using split_device_list to split up sensor and wanted state. The custom constraint is working when in the Test class.
test:
module: test
class: Test
log: test_log
constrain_list:
- input_boolean.input_bool_guest_mode,off
- input_boolean.input_bool_test01,on
- input_boolean.input_bool_night_mode,off
- calendar.skema_fri,off
