I am using WLED integration and notice that the reverse attribute is incorrect.
If I set this attribute to true (via the wled.effect service or via the WLED web interface) the value in the HA UI always remains set to false but the WLED behavior is correct.
I checked the JSON status response from WLED and the reverse attribute is correctly set to true. There is probably a problem in parsing the JSON message in the WLED integration on HA.
Has anyone seen this?
That sounds like you should open an issue.
