Care to share that? Because I generally do sftw before asking questions and did not come across anything useful, nor in the manual. The only thing changeable on the device itself are dip switches that can change the detection angle sensitivity, not the orientation and a siren function (which does not appear to be exposed in the zigbee interface). Turning the siren to the 1-on position does not seem to do anyhing.
I asked the vendor on their support forum. Their advice, which included all details on how, was to tell the device to recalibrate itself, but not quite. The recalibration has to be done in the different orientation (standing on it’s end, not flat).
For anyone else coming along later, looking to use this for a box instead of a garage door,
- Open the unit, find the small button on the circuit board.
- Turn it on then end you want to indicate as ‘open’ facing down
- Quickly press the button inside 5 times
The light will go solid for 3 seconds (do not move it during this) and it will store the new orientation.
For regular use on a garage door you’d calibrate it with the flat side facing down. That way when it’s turned ‘tall’ the door will be read as ‘closed’.
But for use on a box lid you need the opposite. You want the ‘open’ position to read when the unit is turned ‘tall’.
Note that the unit has one pivot angle. The sensor only detects one axis of change on that angle. So make sure you mount it properly.
And when you’re testing to see if your calibration changes worked, note the face of the unit has to be facing up, not the circuit board side. It only reads when the circuit board is facing down. Which is a little problematic as that requires mounting it face side up if you’re going to use it under a lid.
I tested and it does seem to retain the recalibration across battery changes.
The zigbee page for it in HA does show a ‘Calibrate Z axis’ function. I do not know if that would accomplish the same thing as the 5-button sequence or not.
Now the magic question is will it work while inside of a metal dairy delivery box on the front porch!
