Reverse Proxy Cloudflared
I am trying to initiate Cloudfare for remote access have accomplished as logs would indicate but i can’t access remotely i get the error 400 and have copy and pasted the solution
I am new and any help would be much appreciated i feel out of my depth
Loads default set of integrations. Do not remove.
default_config:
  http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/2
4
Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
But this does not solve the problem i looked in the logs below there is a reverse proxy but says my http integration is not set up for reverse proxies
Add-on: Cloudflared
Use a Cloudflare Tunnel to remotely connect to Home Assistant without opening any ports
Add-on version: 5.1.14
You are running the latest version of this add-on.
System: Home Assistant OS 12.4 (aarch64 / yellow)
Home Assistant Core: 2024.7.1
Home Assistant Supervisor: 2024.06.242d7-a92e-e322379e676e event=0 ip=198.41.200.113 location=lhr14 protocol=quic
2024-07-08T14:10:25Z INF Registered tunnel connection connIndex=3 connection=f60cb3cf-9200-483f-ab0c-42b60709c2d0 event=0 ip=198.41.192.27 location=lhr09 protocol=quic
Please format your code correct
f6be36681e0da431418ec7781fb6c62712941803
Sorry got in a mess
