Nevermind. Looks good now. Was pointing at the wrong config file.
thanks for your comment, it was very useful!
I believe Iām having the same problem.
With docker-compose service name and network name are synonymous. So if I use the network name of a service, it should be the same as using the IP of the service. This is the case for the mqtt integration and the mosquitto service I have running, but does not seem to be the case for my ipv4_address
when it comes to the caddy service I have running.
Hereās my docker-compose: tbro-server/docker-compose.yml at 4725320f1224dc73032b0507fa944f4893821fca Ā· TonyBrobston/tbro-server Ā· GitHub
For now Iāve hardcoded the IP of my caddy service, however for whatever reason that IP changed today, so I had to update it; this is the whole point of the network name.
Any advice? Is this a bug?
This will only work for docker services running in bridge network mode. Home assistant runs in āhostā network mode, so you will not be able to reference it from another docker container by container name as it is running outside of the docker network. You will have to spell out the host IP address and add :8123. This would be the same for any of your other containers running in host network mode.
I looked at your compose and do not see any network settings in the compose. Not sure how you hardcoded the IP of the caddy service, but Iām running the swag container and found the only way to keep the IP static and not move around on me is to add the IP into the docker compose.
This is my compose for the swag container defining a static IP
version: "2.1"
services:
swag:
image: linuxserver/swag
container_name: swag
restart: unless-stopped
cap_add:
- NET_ADMIN
volumes:
- /home/tim/docker/swag/config:/config
- /etc/localtime:/etc/localtime:ro
environment:
- PGID=1000
- PUID=1000
- [email protected]
- URL=yourdomain.duckdns.org
- SUBDOMAINS=wildcard
- VALIDATION=duckdns
- TZ=yourtimezone
- DUCKDNSTOKEN=yourtoken
- MAXMINDDB_LICENSE_KEY=yourkey #this is optional for location based IP banning
ports:
- "80:80"
- "443:443"
networks:
default:
ipv4_address: 172.21.0.2
More discussion about this as well on this thread - Nginx Reverse Proxy Set Up Guide ā Docker - #285 by mwav3
@mwav3
Home Assistant only runs in āhostā network mode if you add network_mode: host
to that service in your docker-compose, Home Assistant doesnāt have to run in host network mode. When running containerized services I prefer to expose only exactly what needs exposed.
According to the docker-compose docs (Networking in Compose | Docker Docs):
By default Compose sets up a single network for your app. Each container for a service joins the default network and is both reachable by other containers on that network, and discoverable by them at a hostname identical to the container name.
So in this situation, caddy
is the container name and therefore the hostname; because Iām not running network_mode host, this should just work; and it does work for many other things like my mqtt setup.
The docs also say:
If you make a configuration change to a service and run
docker-compose up
to update it, the old container is removed and the new one joins the network under a different IP address but the same name. Running containers can look up that name and connect to the new address, but the old address stops working.
So, if the IP changes and youāre referencing the hostname in Home Assistantās configuration, then things should be fine.
For now Iāve grabbed the IP out of Home Assistantās logs and hardcoded it here (I also verified that this IP is the IP of my caddy service):
http:
use_x_forwarded_for: true
trusted_proxies: [hardcoded IP here]
I was thinking the configuration should just be (however this doesnāt work, here is the conatiner/network name: tbro-server/home-automation/docker-compose.yml at 4725320f1224dc73032b0507fa944f4893821fca Ā· TonyBrobston/tbro-server Ā· GitHub):
http:
trusted_proxies: caddy
But Iām wondering if it should really be http://caddy
or http://caddy:443
or something along those linesā¦ itās also possible that there is a bug and it doesnāt work by network name, though the docs say it should here: HTTP - Home Assistant
List of trusted proxies, consisting of IP addresses or networks, that are allowed to set the
X-Forwarded-For
header.
Itās also possible to hardcoded the IP of the container in the docker-compose, however this shouldnāt be necessary based on the rest of the info above. I try my best not to subscribe to ājust getting it to workā, less code = less maintenance; I try my best to let the abstractions do their job.
Does anyone else have any ideas? Iām certainly opening to trying some suggestions.
I missed you werenāt running Home Assistant in host networking mode. Technically your supposed to for a āsupportedā install but if your fine without the autodiscovery and arenāt using any integrations that needs host networking mode it will work and then theyāll be on the same docker network.
I know in an nginx config to reference other containers by name you would need to spell out the http - http://container for port 80 or https://container for port 443, but I have no idea if that would work in a Home Assistant config.yaml. You can try it but if not hopefully someone else can chime in.
Just keep in mind that if youāre not running HA in host mode, broadcasts will work neither from nor to HA.
That means no discovery, wol, upnp, ā¦
If you want to default back to the old Home Assistant behavior (e.g. all IPās are whitelisted), here is the config:
http:
trusted_proxies:
- 0.0.0.0/0
This will allow all incoming traffic.
I have discovery working through an mDNS Repeater. This container is ran in host mode, the thought is that itās only doing mDNS Repeating and nothing else; so I can justify running it in host mode. This might seem a little backwards, however I think it complies closer to the, āHow much security is the right amount? As much as possible.ā philosophy. Opening everything up in Home Assistant to the host seems like opening the fire hose when you only want a sprinkle.
I guess it depends how you see containers.
I see them as a convenience, not really as a security mechanism, and definitely not for HA.
From a KISS perspective, adding components to workaround security settings that you decided to implement yourself seem dubious
Worked for me aswell - I am using Traefik as proxy
After my last message I had to edit my configuration to include all addons IPs because when I upgraded and restarted Home Assistant OS the IP of Nginx changed and it broke again.
This is my working configuration:
http:
trusted_proxies:
- 127.0.0.1
- 172.16.0.0/12
- ::1
I am running HA inside a docker container on my Raspberry Pi 3 with nginx as a reverse proxy running on a Raspberry Pi Zero and had the same issue and removing proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
also solved it for me. Thank you for sharing @dvoijen .
@frenck Can you maybe explain the security risk here? I am not to deep into that topic and donāt get it.
this worked for me as well. Thank you
At this point does anyone have a working config for a reverse proxy with apache? Iāve seen configs for ngnix and traefik, but not Apache since about July. Thereās a few threads on it:
In that thread, people are adding their reverse proxy based on an IP being blocked from the logs, I donāt have any log entries about a proxy being blocked.
I have exactly the same issue with the wss to /api/websocket being blocked, however proxy_wstunnel is already enabled.
This whole /api/api thing didnāt change anything.
I documented my Apache config here back in April, and since then Iāve updated my config to allow both my proxy host IP AND the entire /24 subnet of the proxy, no good:
Iām using this and it works for me anyway. Home Assistant is running on host 192.168.1.1 at default port 8123. One of the problems why it didnāt work at first was the end slashes. For some reason theyāre pretty mandatory(?) Also modules like these are required:
- mod_proxy
- mod_rewrite
- mod_http
- mod_headers
<VirtualHost *:443>
ServerName ha.domain.co
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/domain.co/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/domain.co/privkey.pem
ProxyPreserveHost On
ProxyRequests Off
ProxyPass /api/websocket ws://192.168.1.1:8123/api/websocket
ProxyPassReverse /api/websocket wss://192.168.1.1:8123/api/websocket
ProxyPass / http://192.168.1.1:8123/
ProxyPassReverse / http://192.168.1.1:8123/
RewriteEngine On
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteRule ^/?(.*) "ws://192.168.1.1:8123/$1" [P,L]
</VirtualHost>
I was led to this thread, but iām just feeling more confused now. My setup was working just fine (HassOS, NGINX Proxy Manager) until a few days ago when i got a new phone. I got to the login screen, but my login attempt was refused. Also upgraded my PC to Win11, and it also got rejected. I found a āhackā that works, but not for long i suppose, as i added the remote IP range (Cloudflare: 162.158.222.0) to the thrusted proxies. I think my problem is that i have ip_ban_enabled: true
also. As I read the documentation, the use_x_forwarded_for: true
will forward the remote device/service IP to HA, instead of the reverse proxyās IP. But in that case, I would have to enable all possible IP ranges that Cloudflare might use in my case, and that seems counter-intuitive. If I understand this correctly, I donāt see any practical way of combining ip_ban_enabled
and a reverse proxy. Or am I misunderstanding this?
I am relatively new to Home Assistant and have installed Nginx for a separate requirement on a separate Raspberry Pi 4 in a docker container. I am having the same issues as discussed above and attempted different trusted IP addresses with no luck at all.
I can get to the login page but after login I get a message āUnable to connect to Home Assistantā
The log indicates: 2022-01-16 15:11:16 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 110.xxx.xxx.xxx (110.xxx.xxx.xxx). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36 Edg/97.0.1072.55)
Seems like the Nginx is not allowing the authentication to pass through to HA?
I would appreciate any ideas or pointers.
Likely, you didnāt configure nginx properly for websockets.
In case youāre using Nginx Proxy Manager, make sure that youāve enabled the Websockets support on your subdomain
