Can't connect via Apache reverse proxy
I’m trying to configure access to HA on my local network at home.myhouse.local. I’m following the instructions outlined in the post Reverse Proxy with Apache, and I’m not having any luck connecting at all. When I complete the setup in per the article, I get a DNS_PROBE_FINISHED_NXDOMAIN error.
My environment: I’m running HA Supervised with Ubuntu I also haven’t configured SSL yet; it’s on my to-do list, but for now I’m just trying to get up and running through a port 80 proxy. I’m using avahi to publish my server’s domain name on my local network.
Here’s what I’ve done so far; I’ll quote the article as needed:
So you already have a working Apache server available at example.org. Your Home Assistant is correctly working on this webserver and available at http://localhost:8123
Done. I can access both the default Apache page at http://myhouse.local, and my HA instance at http://192.168.x.x:8123
Enable mod_proxy_wstunnel
Done. I’ve got the following Apache mods enabled in addition to mod_proxy_wstunnel:
access_compat.load env.load
alias.load filter.load
auth_basic.load mime.load
authn_core.load mpm_event.load
authn_file.load negotiation.load
authz_core.load proxy.load
authz_host.load proxy_wstunnel.load
authz_user.load reqtimeout.load
autoindex.load rewrite.load
deflate.load setenvif.load
dir.load status.load
Add the following to hass.conf…
Done. Here’s my hass.conf file. Note that I’ve changed the instructions from the original port 443 to port 80, and updated the ServerName with my own. After saving the file, I ran sudo a2enmod hass and then sudo systemctl restart apache2 which returned no errors.
Note that I’ve tried this config with both disablereuse=on and without this text, and I still have the same results
# Home Assistant reverse proxy
# See https://community.home-assistant.io/t/reverse-proxy-with-apache/196942
<VirtualHost *:80>
  ServerName home.myhouse.local
  ProxyPreserveHost On
  ProxyRequests off
  ProxyPass /api/websocket ws://localhost:8123/api/websocket disablereuse=on
  ProxyPassReverse /api/websocket ws://localhost:8123/api/websocket disablereuse=on
  ProxyPass / http://localhost:8123/
  ProxyPassReverse / http://localhost:8123/
  RewriteEngine on
  RewriteCond %{HTTP:Upgrade} =websocket [NC]
  RewriteRule /(.*)  ws://localhost:8123/$1 [P,L]
  RewriteCond %{HTTP:Upgrade} !=websocket [NC]
  RewriteRule /(.*)  http://localhost:8123/$1 [P,L]
</VirtualHost>
When I try to browse to the site, I get a DNS_PROBE_FINISHED_NXDOMAIN error.
I am having the same issue, and I had a working configuration which broke with a recent upgrade. If I may ask, are you getting any useful output in the dev console of say chrome? I get a lot of errors about failing to load source maps.
