I can connect and log into home assistant on my local network @ 10.254.254.6:8123/
When I setup my NGINX reverse proxy server to forward data to my home assistant
NSGINX server ip = 10.254.254.6
I am receiving this error after attempting to login
Unable to connect to Home Assistant.
I have searched and tried every post I can find for days this is my NSGINX config file.
server {
listen 80;
location / {
proxy_pass https://10.254.254.6:8123/;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “upgrade”;
As I stated if I connect directly to Home assistant io it all works.
but when I try to route through NGINX I get the error.
Any help is appreciated I am hosting multiple sites and Need NGINX to work because I only have one public address
Thank You,
Shawn
NGINX Server Version : nginx/1.14.0 (Ubuntu)
IP of server 10.254.254.8
HOME ASSISTANT Version : Home Assistant 0.84.6
IP of server 10.254.254.6
