Using home-assistant v.0.78.3
I follow this docs below, but cannot connect to home-assistant
It’s working fine if setup home-assistant port to 443 and without nginx but using port forwarding on the router.
nginx error.log
2018/09/27 19:03:40 [error] 11989#0: *28 upstream prematurely closed connection while reading response header from upstream, client: 207.123.57.123, server: EXAMPLE.duckdns.org, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:8123/", host: "EXAMPLE.duckdns.org"
2018/09/27 19:03:42 [error] 11989#0: *32 upstream prematurely closed connection while reading response header from upstream, client: xxx.123.57.123, server: EXAMPLE.duckdns.org, request: "GET /service_worker_es5.js HTTP/1.1", upstream: "http://127.0.0.1:8123/service_worker_es5.js", host: "EXAMPLE.duckdns.org", referrer: "https://EXAMPLE.duckdns.org/service_worker_es5.js"
2018/09/27 19:03:43 [error] 11989#0: *32 upstream prematurely closed connection while reading response header from upstream, client: 207.123.57.123, server: EXAMPLE.duckdns.org, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:8123/", host: "EXAMPLE.duckdns.org", referrer: "https://EXAMPLE.duckdns.org/"
2018/09/27 19:03:45 [error] 11989#0: *32 upstream prematurely closed connection while reading response header from upstream, client: 207.123.57.123, server: EXAMPLE.duckdns.org, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:8123/", host: "EXAMPLE.duckdns.org", referrer: "https://EXAMPLE.duckdns.org/"
home-assistant configuration.yaml
# home-assistant http frontend
http:
# Uncomment this to add a password (recommended!)
# server_host: 128.168.1.40
ssl_certificate: /etc/letsencrypt/live/EXAMPLE.duckdns.org/fullchain.pem
ssl_key: /etc/letsencrypt/live/EXAMPLE.duckdns.org/privkey.pem
# base_url: some.random.url
server_port: 8123
#server_port: 443
trusted_networks:
- 127.0.0.1
- 128.168.1.0/24
- 128.168.2.0/24
# trusted_proxies:
# - 127.0.0.1
# - 128.168.1.40
# use_x_forwarded_for: true
