I know there have been a ton of posts on this topic, but none of them quite answer my questions, and I still cannot get this to work. I have set up a docker compose file that runs HA behind NGINX, and run it on my raspberry pi 4:
docker-compose.yml
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /home/ian/development/home-assistant:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
nginx:
image: nginx
ports:
- 443:443
volumes:
- ./nginx:/etc/nginx/conf.d/:ro
- ./certs:/etc/ssl/private/
nginx.conf
upstream homeassistant {
server homeassistant:8123;
server {
listen 443 ssl;
server_name home.<redacted>.com
include /etc/nginx/conf.d/common.conf;
include /etc/nginx/conf.d/ssl.conf;
location / {
proxy_pass http://homeassistant;
include /etc/nginx/conf.d/common_location.conf;
I’m reasonably confident in this part. However, when I go to my pi’s internal IP address I get the 400: Bad Request error, and see the following in the HA logs:
2022-08-18 09:55:37.804 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 172.19.0.2, but your HTTP integration is not set-up for reverse proxies
Which leads me to believe the problem is in my trusted_proxy config in HA. However, I’ve added every IP address I can find, including the one in the error message and the 172.x.x.x subnet, as well as the ip of the PI, all to no avail.
configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
external_url: https://home.<redacted>.com
internal_url: http://localhost:8123
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.19.0.0/16
- 172.0.0.0/8
- ::1
- 127.0.0.1
- 172.16.0.7
- 172.19.0.2
logger:
default: debug
Am I missing something related to this config? As an aside, it doesn’t seem like the logger section does anything either, which is frustrating. Perhaps my config file is malformed?
