Hello everyone,
I am using a relay module which i gave the link at the bottom. This module uses GPIO0 pin’s LOW state for drive the relay. I uploaded this YAML codes to the ESP8266-01;
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "0qH1FtrL3ljWiYMzFFnbYhVKhCAE+ZsNjcUaAI1S7Mg="
ota:
password: "de11ca42a2509b9737dcd0e877409b06"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Thermostatkombi Fallback Hotspot"
password: "Xr3UlY3bqAmv"
captive_portal:
switch:
- platform: gpio
pin: 0
I am using the COM and NO terminals for switching on the my boiler. But when i send the turn on boiler command with “switch.turn_on” in the automatin codes ESPHome sends the HIGH to the GPIO0 and relay remains turn off. But when i send the turn off boiler command with “switch.turn_off” then ESPHome sends LOW to the GPIO0 and relay turns on. This is no problem in coding for me. I changed all the “on” commands to “off” and “off” commands to “on” but when i go to the dashboard It appears to be “on” when the boiler is “off”.
Is there any way to change dashboard’s card for boiler status from on to off and vice versa? Also may be there is a way for ESPHome to change the state of the GPIO0 pin.
Thanks in advance…
