i don’t know the url yet. This is what I get if I check the Console on the vm200. As far as i see it from the guide, checking the console on the vm200 should bring up the HA console (which would display the IP too), but I only get the screen attached above
is it a problem, that during the VM setup I only have local-lvm for EFI storage and not local-zfs ? I guess, not since the guide shows any of those is okay
i’m afraid it’s the same this shouldn’t take this long. on RPI4 this file was restored in 5 minutes. on the VM (which is on a much better hardware) it’s been going on for like 10 minutes
Sometimes restores can take a very long time. In most instances with restoration issues, I suggest a clean setup from zero, VM → HAOS.
Restores can take a log time or never complete when inconsistencies between hardware cannot be resolved. This is why sometimes it is faster and safer to just start greenfield.
yep, i decided to do that. Thank you for the guide, it is clean, easy to follow and works perfectly. Is it okay by the way that the haos VM uses 63% of memory all the time?
Disregard the Proxmox reported values of VM usage. HAOS does not communicate this info to Proxmox. If you want to see the real stats in HA visit: Settings → System → Hardware.
