Reverting back to latest docker build (back from dev) - HA container has errors and won't start now
Hello - I wanted to test out the dev build, so I updated my docker compose to the dev flag. After kicking the tires for a few minutes, I wanted to go back to the latest build, but now HA won’t launch after reverting back. Can someone see what the issue is?
Is there a specific process I should’ve followed to “clean” my docker config directory for HA to revert back successfully?
2020-05-13 16:56:16 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
  File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 355, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 347, in main
    exit_code = asyncio.run(setup_and_run_hass(config_dir, args), debug=args.debug)
  File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
    return loop.run_until_complete(main)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 587, in run_until_complete
    return future.result()
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 253, in setup_and_run_hass
    safe_mode=args.safe_mode,
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 94, in async_setup_hass
    await async_from_config_dict(config_dict, hass) is not None
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 168, in async_from_config_dict
    await conf_util.async_process_ha_core_config(hass, core_config)
  File "/usr/src/homeassistant/homeassistant/config.py", line 468, in async_process_ha_core_config
    await hass.config.async_load()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1443, in async_load
    self._update(source=SOURCE_STORAGE, **data)
TypeError: _update() got an unexpected keyword argument 'external_url'
I pulled down the beta tag, and am functional again. However, moving forward, what is my best course of action? Do I specify a specific version until “latest” meets or supersedes the current beta version I’m at?
Before I had a life changing event in December (moving, etc…), I had disabled my nightly cron job that took a backup of my docker directory, so I don’t have anything to fall back/restore from.
Just trying to avoid running into this breaking issue in the future, or is it best to fall on the sword now and start over fresh?
I had the same issue. The problem is in /config/.storage/core.config. There are external_url and internal_url JSON objects created in the 0.110 beta that aren’t used in versions < 0.110. Removing those objects fixed the issue.
This is actually a bug!
The core should be able to start with additional data in the core configuration (as we do on other places as well). It should be able to handle that.
While I cannot change history (previous releases) I will ensure this is handled gracefully for the future. Writing up a fix for 0.110.
PR to address this: https://github.com/home-assistant/core/pull/35660
Thanks Karson, I also had the same problem and thanks to you I solved it. :smiley:
