Since the 1st of October ChatGPT supports automatic prompt caching on most of its concurrent models. This automatically matches prompts to ones in the cache to reduce time and cost. However, the matching is done by looking at the tokens in order, so if the first token does not match any in the cache it cannot use the cached tokens. Also see the docs: prompt caching.
The current prompt starts with the BASE_PROMPT which is the time. The time changes every second and therefore there is no possibility to use the cache as the start of the prompt changes every time.
I was wondering if the prompt could be rewritten to better support this new prompt caching feature by at least changing the time to be later on in the prompt and ideally by sorting the past states in reverse order of last updated.
Hi @hugobloem
Don’t forget to vote for your own feature request
Hi Hugo, the same is true for the anthropic integration. see the anthropic docs: prompt caching
It seems to me that there can be significant savings, especially if you are using the continuous conversation feature (this seems to be triggered when the model ends the response with a question, which is part of my service prompt in the integration).
Seperating the timestamp from the static parts (like the prompt from the service, adjustable by the user) and the inventory part (which is generated by the system) and the tools part would be a good practice.
Keep in mind that the pricing structure changes (for anthropic at least) when activating caching (so it should be a flag you can toggle in the service configuration)
Upvoting this!
The un-cacheable system prompt is especially problematic with local LLM installs.
For example; through some experimentation I have been able to get the prompt eval times from >4100ms to around 349ms by reformatting the system prompt in ollama webui.
