HI,
rewriting all conditions in the form of value_template, to easily check them in the dev-templates, what would be the best way to transform this:
- condition: time
before: '21:00:00'
after: '08:30:00'
into this form:
condition: template
value_template: >
{{ '08:30:00'< now().timestamp() < '21:00:00' }}
or
{{'08:30'< states('sensor.time') < '21:00'}}
petro
(Petro)
October 3, 2018, 1:18pm
2
You’ll have to convert them to seconds for this to work. String operations on numbers does not work the way you think it does.
{{ (8*60*60+30*60) < state_attr('sensor.time','timestamp') < 21*60*60 }}
thank you, I’ll do that, seems a bit hacky though. Isn’t there a better way? I merely tried the setup with sensor.time, because it passed the template checker and the shortest time display without further timestamps etc.
does seem to work though;-)
your template renders empty…
because this:
{{state_attr(‘sensor.time’,‘timestamp’)}} is None ?
petro
(Petro)
October 3, 2018, 1:33pm
4
Hmm, i thought that had a timestamp attribute. Use as_timestamp(states(‘sensor.time’))
As for your little example, let me show you why string representations of numbers do not work:
not yet…
btw using 09:33 makes it work correctly ? no matter which silly times I enter, it always is correct and evaluates the current time correctly too, unless of course I go over the 60 for the minutes…
this would be possible I think:
{{ (8*60*60+30*60) < ((now().hour)*60*60 + (now().minute)*60) < 21*60*60 }}
which would be the same as:
{{ (8*60 + 30) < ((now().hour)*60 + (now().minute)) < 21*60 }}
or even
{{ 8*60 + 30 < now().hour*60 + now().minute < 21*60 }}
petro
(Petro)
October 3, 2018, 5:23pm
6
are you actually using sensor.time? Is sensor.time from the time component or is it something you made?
petro
(Petro)
October 3, 2018, 5:25pm
7
Also, if you are looking for the simplest approach, you could keep your units in hours:
{{ ( 8 + 30/60 ) < ( now().hour + now().minute/60 ) < ( 21 + 33/60 ) }}
or in decimal format:
{{ 8.5 < ( now().hour + now().minute/60 ) < 21.55 }}
well, yes, sure. I use:
- platform: time_date
display_options:
- 'time'
- 'date'
- 'beat'
cool, getting better. As a matter of fact, I’d need the times to be between 07 am and 21 pm, so
{{ 7 < ( now().hour + now().minute/60 ) < 21 }}
nice! thanks
