hi
im trying to automate my rf controlled blindes with no feedback.
i would like to be able to control it with a up/down switch and also be able to stop it while it moves.
since i also have another rf remote i don’t want to block the controlls with time to much so i still can use both.
any ideas?
amaximus
(Atticus Maximus)
August 12, 2021, 12:16pm
2
here is how I did it for RF433 (no-rolling code) blinds:
platform: mqtt
state_topic: "sonoffrf433/tele/RESULT"
json_attributes_topic: "sonoffrf433/tele/RESULT"
value_template: >-
{% if value_json.RfRaw.Data| regex_search('28181819081800000000000909090819090819081818181909\s55') %}
blinds_open
{% elif value_json.RfRaw.Data| regex_search('28190908181909090909081900000000000819081819090818\s55') %}
blinds_close
{% elif value_json.RfRaw.Data| regex_search('281909081819090909090819111111100000819081819090818\s55') %}
blinds_stop
{% endif %}
create input booleans for blinds_open and blinds_remote
do automations for blinds_open, blinds_close (when controling from HA):
alias: "RF433 reluxa close"
initial_state: "on"
platform: state
entity_id: sensor.rf433
to: "blinds_close"
entity_id: input_boolean.blinds_remote
- service: input_boolean.turn_off
entity_id: input_boolean.blinds_open
and blinds_remote:
alias: "Blinds remote post action"
initial_state: "on"
platform: state
condition:
- condition: state
state: 'on'
- delay: 00:00:04
and rf433_blinds_close and rf433_blinds_open for the case when using the RF remote:
alias: "RF433 blinds close"
initial_state: "on"
platform: state
to: "blinds_close"
blinds:
friendly_name: "Bedroom blinds"
value_template: >-
{% if states('input_boolean.blinds_open') == "on" %}
open
{% else %}
closed
{% endif %}
open_cover:
service: script.blinds_open_script
close_cover:
service: script.blinds_close_script
stop_cover:
service: script.blinds_stop
icon_template: >-
{%- if is_state('input_boolean.blinds_open', 'on') -%}
mdi:window-shutter-open
{%- else -%}
mdi:window-shutter
{% endif %}
define the scripts to control the blinds:
blinds_open_script:
alias: 'Open blinds script'
sequence:
blinds_close_script:
alias: 'Close blinds script'
sequence:
blinds_open:
alias: 'Open blinds'
sequence:
- service: mqtt.publish
data_template:
topic: sonoffrf433/cmnd/Backlog
retain: false
payload: "RfRaw AAB035050812C005E602D001682000000002A3B2B2B2B2A3A3B2A3B2B2A3A3B2A3B2A3B2B2B2A3B2B2B2B2B2A3B2B2B2A3B2B2B2A55"
- delay:
seconds: 1
data_template:
retain: false
payload: "RfRaw 177"
blinds_close:
alias: 'Close blinds'
sequence:
data_template:
retain: false
payload: "RfRaw AAB035050812C005F002BC017C2774481A000000000000000A3B2A3B2B2A3A3B2A3B2A3B2B2B2A3B2B2B2B2B2A3B2B2A3A3B2B2A3A55"
- delay:
seconds: 1
data_template:
retain: false
blinds_stop:
alias: 'Stop blinds'
sequence:
data_template:
retain: false
payload: "RfRaw AAB035050812AC05F002B201722788481A3B2A3A000000000000002A3B2B2A3A3B2A3B2A3B2B2B2A3B2B2B2B2B2A3B2A3B2A3B2A3B2A55"
- delay:
seconds: 1
data_template:
retain: false
blinds_toggle:
alias: 'Toggle blinds'
sequence:
- service: "script.blinds_{% if is_state('cover.blinds', 'closed')%}open{% else %}close{% endif %}"
blinds_toggle_script:
alias: 'Toggle blinds script'
sequence:
service: input_boolean.toggle
This will ensure that the state of the input_boolean.blinds_open is consistant regardless of using HA or the RF remote to control the blinds.
The rest is UI magic.
I hope I did not miss anything.
Madhousedk
(Tom Mathiasen)
October 30, 2021, 8:49pm
3
Hello thanks for your post.
I cant get it to work, can you please specify where you enter the code you posted aka which files each code piece belong to.
Thanks in advance
Tom
amaximus
(Atticus Maximus)
November 1, 2021, 1:51pm
4
The first one (platform: mqtt) goes into sensors; the 2nd-4th ones go into automations, the fifth one (cover) goes into cover and the sixth section (blinds_open_script, blinds_close_script, blinds_open, etc) goes into script.
The above structuring presumes the following configuration.yaml
automation: !include_dir_list automations
cover: !include covers.yaml
script: !include scripts.yaml
sensor: !include_dir_list sensors
namely each automation and sensor is a file in the automations and the sensors directory respectively, while covers.yaml contains all definitions for all covers, like:
platform: template
covers:
blinds:
friendly_name:...
and scripts.yaml lists all scripts.
Hey @amaximus
This is exactly what I’m after but I’m having trouble getting it working
Do you have your current config for this hosted anywhere that I can look at?
