so I have an ESP32 set up to be a 433 MHZ remote receiver which, above other things, I use to capture pushbutton I have around the house to trigger actions.
So far no issue at all but recently I bought a bunch of (cheap) pushbutton which I am not able to make them work correclty.
My code for remote receiver is:
remote_receiver:
pin:
number: 27
dump: rc_switch
tolerance: 25% # default is 25%
filter: 10us # default is 10us
idle: 9ms # default is 10ms
while for pushbutton I have:
- platform: remote_receiver
filters:
- delayed_off: 750ms
rc_switch_raw:
code: '110010111110110011100001'
protocol: 1
and this is working very well with DIGOO DG-HOSA while other very similar button I bought are really not consistent in the signal I capture with ESP32.
What I mean is that pushing the button sometimes I get “10010100101” and sometime “1001010010100011” for example or different combination of length (binary values are always the same obviously).
I tried a bit to play with
- tolerance
- filter
- idle
values but without much luck in stabilizing the received signal.
Does anyone have hints about how to reception stablity?
P.S. it is not a distance issue as even at 10cm far from the receiver situation doesn’t change
