RF Converter V3.0 custom integration
Recently, I’ve created custom integration for RF Converter V3.0 WiFi to Remote.
Click here to download
Feel free to give me any feedback.
Thank you.
Thanks! Great job!..
The RF Converter module does not respond to sending a packet from Home Assistant.
reload_remote - retrieves the data correctly:
{"ecostar": {"ip": "192.168.2.28", "mac": "08:3a:8d:ee:2a:4f", "type": "1", "project": "13", "frequency": "43392", "id": "1726589522", "key": {"garaz": "32", "wjazdowa": "64"}}}
send_command - it’s visible that the packet was sent to the RF module, but the LED on the RF, which signals task execution, does not react (192.168.1.101 is my Home Assistant).
root@router:/tmp/home/root# cat /proc/net/nf_conntrack | grep 192.168.2.28
ipv4     2 tcp      6 1085 ESTABLISHED src=192.168.2.28 dst=47.254.152.213 sport=30327 dport=8950 src=47.254.152.213 dst=10.100.0.2 sport=8950 dport=30327 [ASSURED] mark=0 use=2
ipv4     2 udp      17 28 src=192.168.1.101 dst=192.168.2.28 sport=39109 dport=26258 [UNREPLIED] src=192.168.2.28 dst=192.168.1.101 sport=26258 dport=39109 mark=0 use=2
Where else can I look for a solution to the problem?
Sorry for the late response. Since the RF converter communicates on layer 2, it needs to be on the same network as the Home Assistant. I guess 192.168.1.101 and 192.168.2.28 are on different subnets, so they won’t be able to communicate each other.
Thanks for the response. I switched to the same network, but the converter still doesn’t respond to the command.
I’m attaching the packet send and receive capture from Wireshark.
First, please ensure that Smartmate app is working correctly. Next, how did you capture packets with Wireshark? Normally, Layer 2 packets cannot be captured because they are only passed through a switch hub. Lastly, please post the binary of the captured packet, and I’ll check for any issues. Thank you.
Yes, the Smartmate app is working correctly. The gate opens, and the green LED lights up on the RF Converter V3.0 device.
I suspect that the data being sent is incorrect or the checksum is off.
When sending the packet through this integration, the blue Wi-Fi LED on the RF Converter V3.0 blinks, but the green LED, which indicates the signal being sent to the gate, remains red.
Thank you for your help.
No.     Time           Source                Destination           Protocol Length Info
   1078 6.663952       192.168.2.30          192.168.2.28          UDP      85     26258 → 26258 Len=43
Frame 1078: 85 bytes on wire (680 bits), 85 bytes captured (680 bits) on interface \Device\NPF_{0F4E7421-ABE4-4575-85A5-6F700304567D}, id 0
Ethernet II, Src: Intel_de:65:4d (04:e8:b9:de:65:4d), Dst: Espressif_ee:2a:4f (08:3a:8d:ee:2a:4f)
    Destination: Espressif_ee:2a:4f (08:3a:8d:ee:2a:4f)
        .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
        .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
    Source: Intel_de:65:4d (04:e8:b9:de:65:4d)
    Type: IPv4 (0x0800)
    [Stream index: 6]
Internet Protocol Version 4, Src: 192.168.2.30, Dst: 192.168.2.28
User Datagram Protocol, Src Port: 26258, Dst Port: 26258
Data (43 bytes)
0000  fe 01 01 0d 04 e8 b9 de 65 4d 08 3a 8d ee 2a 4f   ........eM.:..*O
0010  00 00 00 00 00 00 00 00 02 01 00 0c 66 e9 aa 52   ............f..R
0020  00 00 00 00 a9 80 40 00 00 75 ef                  [email protected].
   1082 6.685618       192.168.2.28          192.168.2.30          UDP      73     26258 → 26258 Len=31
Frame 1082: 73 bytes on wire (584 bits), 73 bytes captured (584 bits) on interface \Device\NPF_{0F4E7421-ABE4-4575-85A5-6F700304567D}, id 0
Ethernet II, Src: Espressif_ee:2a:4f (08:3a:8d:ee:2a:4f), Dst: Intel_de:65:4d (04:e8:b9:de:65:4d)
    Destination: Intel_de:65:4d (04:e8:b9:de:65:4d)
    Source: Espressif_ee:2a:4f (08:3a:8d:ee:2a:4f)
    Type: IPv4 (0x0800)
    [Stream index: 6]
Internet Protocol Version 4, Src: 192.168.2.28, Dst: 192.168.2.30
Data (31 bytes)
0000  fe 02 01 0d 08 3a 8d ee 2a 4f 04 e8 b9 de 65 4d   .....:..*O....eM
0010  00 00 00 00 00 00 00 00 02 01 00 00 00 e6 ef      ...............
   1101 7.074682       192.168.2.28          192.168.2.30          UDP      74     26258 → 26259 Len=32
Frame 1101: 74 bytes on wire (592 bits), 74 bytes captured (592 bits) on interface \Device\NPF_{0F4E7421-ABE4-4575-85A5-6F700304567D}, id 0
    Type: IPv4 (0x0800)
    [Stream index: 6]
User Datagram Protocol, Src Port: 26258, Dst Port: 26259
Data (32 bytes)
0000  fe 01 01 0d 08 3a 8d ee 2a 4f 04 e8 b9 de 65 4d   .....:..*O....eM
0010  00 00 00 00 00 00 00 00 21 01 00 01 00 00 08 ef   ........!.......
   1123 7.574880       192.168.2.28          192.168.2.30          UDP      74     26258 → 26259 Len=32
Frame 1123: 74 bytes on wire (592 bits), 74 bytes captured (592 bits) on interface \Device\NPF_{0F4E7421-ABE4-4575-85A5-6F700304567D}, id 0
    Type: IPv4 (0x0800)
    [Stream index: 6]
Data (32 bytes)
   2067 11.646526      Intel_de:65:4d        Espressif_ee:2a:4f    ARP      42     Who has 192.168.2.28? Tell 192.168.2.30
Frame 2067: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface \Device\NPF_{0F4E7421-ABE4-4575-85A5-6F700304567D}, id 0
    Type: ARP (0x0806)
    [Stream index: 6]
Address Resolution Protocol (request)
    Hardware type: Ethernet (1)
    Protocol type: IPv4 (0x0800)
    Hardware size: 6
    Protocol size: 4
    Opcode: request (1)
    Sender MAC address: Intel_de:65:4d (04:e8:b9:de:65:4d)
    Sender IP address: 192.168.2.30
    Target MAC address: Espressif_ee:2a:4f (08:3a:8d:ee:2a:4f)
    Target IP address: 192.168.2.28
   2068 11.647935      Espressif_ee:2a:4f    Intel_de:65:4d        ARP      42     192.168.2.28 is at 08:3a:8d:ee:2a:4f
Frame 2068: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface \Device\NPF_{0F4E7421-ABE4-4575-85A5-6F700304567D}, id 0
    Type: ARP (0x0806)
    [Stream index: 6]
Address Resolution Protocol (reply)
    Hardware size: 6
    Protocol size: 4
    Opcode: reply (2)
    Sender MAC address: Espressif_ee:2a:4f (08:3a:8d:ee:2a:4f)
    Sender IP address: 192.168.2.28
    Target MAC address: Intel_de:65:4d (04:e8:b9:de:65:4d)
    Target IP address: 192.168.2.30
Thank you for the detailed post. The packets were sent from 192.168.2.30 to 192.168.2.28 four times, and they’re not same. Could you please specify in more detail how you called send_command each time? and how your remote controllers are registered in Safemate app?
Hi, this doesn’t work. It can retrieve all the data, but when sending a command, nothing happens. Have you tested this yourself ?
2024-11-27 00:40:16.659 WARNING (SyncWorker_20) [custom_components.rf_converter] Remote [SOMMER]/[key1] not found
2024-11-27 00:51:19.382 WARNING (SyncWorker_14) [custom_components.rf_converter] Remote [SOMMER]/[key] not found
2024-11-27 00:51:22.548 WARNING (SyncWorker_5) [custom_components.rf_converter] Remote [SOMMER]/[key] not found
Tried to test as seperate python file too without success…Any idea ? Data is fetched correctly, but i think there is some logical issue with how UDP packet is built…
import requests
import socket
import uuid
import json
class rf_converter:
    def __init__(self):
        self.remote_data = {}
        self.sequence = 0
    def GetRemote(self, requesturlbase, account, security_code, headers):
        try:
            # Fetch device data
            device_response = requests.post(
                requesturlbase + 'get_all_device_data.php',
                data={'account': account, 'security_code': security_code},
                headers=headers
            device_response.raise_for_status()
            devices = device_response.json()
            if devices['result'] == 0:
                # Process devices
                for device in devices['message']:
                    mac = device['mac']
                    remote_response = requests.post(
                        requesturlbase + 'get_remote_controller.php',
                        data={'mac': mac, 'security_code': security_code},
                        headers=headers
                    remote_response.raise_for_status()
                    # Log the JSON response from the remote controller API
                    remotes = remote_response.json()
                    print(f"Remote response for MAC {mac}: {json.dumps(remotes, indent=4)}")
                    if remotes['result'] == 0:
                        for remote in remotes['message']:
                            r_name = remote['r_name']
                            self.remote_data[r_name] = {
                                'ip': device['ip'],
                                'mac': mac,
                                'type': device['type'],
                                'project': device['project'],
                                'frequency': remote['frequency'],
                                'id': remote['id'],
                                'key': {key['k_name']: key['value'] for key in remote['key']}
            return devices['result']
        except Exception as e:
            print(f"Error in GetRemote: {e}")
            return -1
    def Checksum(self, crc_data, length):
        checksum = 0
        for byte in crc_data[:length]:
            checksum ^= byte
            for _ in range(8):
                if checksum & 1:
                    checksum = (checksum >> 1) ^ 0x8C
                else:
                    checksum >>= 1
        return checksum
    def PacketBuilder(self, device_type, device_project, sender, receiver, remote_id, frequency, key_value, sequence, remote_name=None, key_name=None):
        try:
            packet = bytearray()
            packet.append(0xFE)  # Start of packet
            packet.append(1 if key_value is not None else 2)  # Command type
            packet.append(int(device_type) & 0xFF)
            packet.append(int(device_project) & 0xFF)
            packet.extend(bytes.fromhex(sender.replace(':', '')))
            packet.extend(bytes.fromhex(receiver.replace(':', '')))
            packet.extend(b'\x00' * 8)  # Reserved bytes
            if key_value is None:
                packet.extend(b'\x21\x01\x00\x00')  # General command
            else:
                packet.extend(b'\x02\x01\x00\x0C')  # Key-specific command
                packet.extend((int(remote_id) & 0xFFFFFFFF).to_bytes(4, 'big'))
                packet.extend(b'\x00' * 4)  # Reserved
                packet.extend((int(frequency) & 0xFFFF).to_bytes(2, 'big'))
                packet.append(int(key_value) & 0xFF)
                packet.append(0x00)  # Key terminator
            # Add remote name and key name
            if remote_name:
                remote_name_bytes = remote_name.encode('utf-8')[:16]
                packet.extend(remote_name_bytes.ljust(16, b'\x00'))
            if key_name:
                key_name_bytes = key_name.encode('utf-8')[:16]
                packet.extend(key_name_bytes.ljust(16, b'\x00'))
            packet.append(sequence & 0xFF)
            packet.append(self.Checksum(packet, len(packet)))
            packet.append(0xEF)  # End of packet
            print(f"Composed UDP Packet: {packet.hex()}")
            return packet
            print(f"Error in PacketBuilder: {e}")
            return None
    def CreatePacket(self, remote, key):
        try:
            if remote in self.remote_data:
                remote_info = self.remote_data[remote]
                if key in remote_info['key'] or key == '':
                    packet = self.PacketBuilder(
                        remote_info['type'],
                        remote_info['project'],
                        f'{uuid.getnode():x}',
                        remote_info['mac'],
                        remote_info['id'],
                        remote_info['frequency'],
                        None if key == '' else remote_info['key'][key],
                        self.sequence,
                        remote_name=remote,
                        key_name=key if key else None
                    self.sequence = (self.sequence + 1) & 0xFF
                    return remote_info['ip'], packet
            return None, None
            print(f"Error in CreatePacket: {e}")
            return None, None
    def SendCommand(self, remote, key):
        try:
            ip, packet = self.CreatePacket(remote, key)
            if ip and packet:
                with socket.socket(socket.AF_INET, socket.SOCK_DGRAM) as sock:
                    sock.sendto(packet, (ip, 26258))
                print(f"Command sent to {remote} with key {key}.")
                return True
            print(f"Failed to create packet for remote: {remote}, key: {key}")
            return False
            print(f"Error in SendCommand: {e}")
            return False
# Example Usage
if __name__ == '__main__':
    converter = rf_converter()
    # Configuration
    request_url = 'http://47.254.152.213/yetcloud_release/'
    account = 'xxxx'
    security_code = 'DSKWIJAKZXLQPSZMANXVTBFGYHPNVCRE'
    headers = {
        'Content-Type': 'application/x-www-form-urlencoded',
        'Connection': 'keep-alive',
        'Accept': '*/*',
        'User-Agent': 'Custom-Agent'
    # Fetch remote data
    if converter.GetRemote(request_url, account, security_code, headers) == 0:
        print("Remote data fetched successfully.")
    else:
        print("Failed to fetch remote data.")
    # Send command
    if converter.SendCommand('Sommer', 'key1'):
        print("Command sent successfully.")
    else:
        print("Failed to send command.")
C:\Kapi>python test.py
Remote response for MAC d8:3b:da:1c:03:e0: {
“result”: 0,
“message”: [
“mac”: “d8:3b:da:1c:03:e0”,
“r_order”: “1”,
“r_name”: “Sommer”,
“id”: “1732662252”,
“brand”: “10”,
“speed”: “0”,
“frequency”: “86880”,
“key”: [
“k_order”: “1”,
“k_name”: “key1”,
“image”: “14”,
“type”: “0”,
“value”: “32”
“k_order”: “2”,
“k_name”: “key2”,
“image”: “15”,
“type”: “0”,
“value”: “64”
“k_order”: “3”,
“k_name”: “key3”,
“image”: “16”,
“type”: “0”,
“value”: “128”
“k_order”: “4”,
“k_name”: “key4”,
“image”: “17”,
“type”: “0”,
“value”: “16”
Composed UDP Packet: fe01010f5414f377493ed83bda1c03e000000000000000000201000c674653ec0000000053602000536f6d6d6572000000000000000000006b6579310000000000000000000000000029ef
Command sent to Sommer with key key1.
C:\Kapi>
Remote and Key are case sensitive. Please try sending command with remote name ‘Sommer’ instead of ‘SOMMER’.
And your seperated python file does not create correct packet. You added remote and key name into packet, and should not.
Hi tested sending a command using Sommer as the remote and key1 as the key. The command seems to be processed successfully, as there are no errors in the logs. However, the target device does not respond (e.g., no blinking or action).
Interestingly, when I use a random key instead of key1, the logs show the following error:
2024-12-09 00:47:33.513 WARNING (SyncWorker_16) [custom_components.rf_converter] Remote [Sommer]/[A] not found
This indicates that the system recognizes Sommer and key1 as valid inputs, but the device still fails to react.
Thank you for your comment.
  1. Make sure that the Home Assistant and RF Converter are within the same subnet for layer 2 communication.
  2. What type is your remote (Sommer and key1)? Are they built-in pre-configured ones or DIY learned keys? I have only tested DIY remote keys, and there’s a chance that built-in keys may not work.
I don’t see any example of how to create an RF-sending-command button in the dashboard. Anyone know how to do it?
Hi all, thanks to the op for the work getting the rf converter integrated. One of the only cheap bridge devices that can do rolling codes!
I’m just testing this for the first time however not having any luck. I did notice there was a ha update just after the op’s last commit that depreciated service and renamed to it action which may have broken the integration.
Is it still working?
Thanks :pray:
Hi there - anyone got this working? I have ordered this remote which works perfectly with the app Safemate, but I can’t seem to get the custom integration working properly. Sending comments (via the new “Action” tab) says actions performed correctly but no reaction from the remote
It functions on HA Core 2025.3 currently. However, it may only support custom remote, as others not to be implemented.
this integration works with hardware RF Converter V2.0 ?
The hardware difference is only in the antenna
Since I don’t have V2, I’m not sure if it works or not. If you have one, would you try it by yourself.
