I have a Velux blind with a remote to control them. According to the manufacturer they use rolling codes. I know my sonoff RF bridge cannot recreate the codes correctly. The manufacturer sell a bridge, but it’s 80 Euros which I don’t really like to spend. Are there any other options that I am currently unaware of? Any help/ideas I would appreciate!
Neither of those two posts will help. You can sniff as many codes as you like but without knowing the way the rolling code is generated you are shit out of luck. Even rolljam is no use in this case (and more expensive than the bridge). Buy the bridge.
I doubt there’s any major encryption involved in a Velux blind code. I’m sure if you sniffed the codes you would recognise a pattern. If nothing else it would be an interesting project.
VELUX use the IO Homecontrol protocol - same as some Somfy products, and it can not be cloned or replayed. You can buy the KLF 200, or use dry contacts on the small remote. The KLF is two way, and will give you status updates regarding positions.
No one had any luck reverse engineering the velux io home control protocol. But you can hack a velux remote and use relays to “press” the buttons on the remote.
It’s ugly but it does work.
I used a 2 channel (one for up and one for down) tasmota compatible relay board, and a cheap 2nd hand remote:
Btw the top photo was my 1st attempt where I powered the remote from gnd/3v3 supply on the relay board. Seems it blew the remote don’t know why.
So now my v2 uses batteries for the remote.
Hi James, @hijinx
Digging up this thread. Could you help me understand how you achieved your setup (i. E. Wiring, parts and software)
I am in the same situation with a similar remote and unfortunately have no clue how to progress…
Best regards
