Hi all,
I have been using HomeAssistant for around a week now. I am very pleased with the platform and have found the community very helpful so far.
There is one issue that I have been unable to fix thus far:
My Zigbee (Sonoff ZBDongle-P) coordinator has great difficulty pairing with battery powered devices (from Ikea). Also binding and OTA don’t work (except for 1 sensor, where binding succeeded after many attempts). Once paired, the sensors and remotes work just fine. Also AC powered devices like lamps and smart sockets pair just fine.
I found that there is a specific spot in my house that works somewhat (with around 25% chance of success). That spot is about 4 meters away from the antenna. If I come too close then pairing will fail, if I go to far then pairing also fails. (In the paring GUI, the blue window gets stuck at interrogating or something similar, forever, it never turns green. If I abort at that point, then I end up with a Zigbee device without any capabilities).
One remote (Ikea on/off switch) was so bad that it took over 10 attempts to pair.
When I look at the visualization of my Zigbee mesh, then I notice that the coordinator’s LQI numbers are very assymetric (one LQI is 1/2 to 1/3 of the other LQI).
Is suspect that the following two things are going wrong:
- The transmit power of my stick is too high, while the receive sensitivity is too low.
(this would explain the very specific distance for pairing and the asymmetrical LQI; Too close and the receiver antenna gets over saturated, too far and the responses are not received) - The pairing communication is not coming in via the mesh, only directly to/from the coordinator.
Is this normal behavior, is my stick defective or am I doing something wrong?
Now I am dreading the day that I have to re-do a pairing. Also I cannot make my setup robust by binding the remotes to groups of lamps (I want my lights to remain functional even if HA is down for some reason). And I can never update my remotes this way…
btw, my ZBDongle-P is runnning firmware version “Z-Stack 20230507”, that I grabbed from Koenkk’s GitHub Z-Stack-firmware/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20230507.zip at 245509ce59320bf2a08e3131b519d824ecb0066c · Koenkk/Z-Stack-firmware · GitHub
