RF Link Gateway
Hi Automators,
I’ve installed my RFlinkGateway, and HA recognises it and can apparently communicate with it at least to start with…
2017-08-10 11:13:42 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2017-08-10 11:13:42 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2017-08-10 11:13:42 DEBUG (MainThread) [rflink.protocol] connected
… however the auto detect sensors and lights does not work and I cant switch anything on/off nor do my sensors ever report anything (I put the switches and sensors in manually as suggested by @Rune )
In the logs I get…
2017-08-10 15:27:49 DEBUG (MainThread) [rflink.protocol] sending command: {‘command’: ‘off’, ‘id’: ‘41’, ‘protocol’: ‘kaku’, ‘switch’: ‘16’}
2017-08-10 15:27:49 DEBUG (MainThread) [rflink.protocol] writing data: ‘10;kaku;41;16;off;\r\n’
2017-08-10 15:27:49 DEBUG (MainThread) [rflink.protocol] waiting for acknowledgement
2017-08-10 15:27:49 DEBUG (MainThread) [homeassistant.components.rflink] Sending command: off to Rflink device: kaku_41_1
2017-08-10 15:27:54 WARNING (MainThread) [rflink.protocol] acknowledge timeout
So I’m thinking HA is not communicating with the gateway at all. When I connect the gateway to my PC with the loader program it all works fine and i can see the switches and can receive sensor data, but now I’m at a loss as to how to debug it. I’m currently on HA 50.2 and RF Link R46. Is anyone else having any problems with this combination?
OK, it seems that the USB port was not working properly, it’s working properly now :slight_smile:
