RF motion sensor - how to start?
-Hi,
I have Raspi3 with RXB6 433MHz receiver. Cheap chinese IR motion sensor (not sure if it sends ON status only)
1, Which PIN on Raspi3 should I connect DATA from RXB6 ?
2, Should I set the sensor (they will be 4) as switch or sensor or something else?
3, Which component to use?
Thank you very much!
You need a bit more to decode the 433Mhz signals to be used in Home Assistant.
You could use RFLink for this.
This involves a bit more hardware.
Are you sure? Some people here use cheap RF receivers without any additional HW. Check here https://youtu.be/5UUazFbK-Hg
