Hey everyone! I hope this is the correct place to post this.
I just wanted to share an add-on that I’ve been working on the past week or so. It simplifies the reading of the codes needed to use the rpi-rf integration.
Home Assistant Add-on: GPIO RF Reader
Reads radio frequency signal codes off of a Raspberry Pi GPIO pin.
This add-on provides a simple way to read the radio frequency codes from a GPIO pin of a Raspberry Pi wired with generic 433/315MHz capable modules.
Uses the Python library rpi-rf and script rpi-rf_receive . More details about wiring and hardware can be found on the rpi-rf site.
This add-on has been tested with a RPi 4b running Home Assistant and will probably work with a 3b/3b+ .
