I’ve come accross multiple solutions where existing access control systems were used to signal HomeAssistant to disarm alarms, open doors, etc.
Howeve I’m looking for a professionL looking solution where I can manage access through Homeassistant (e.g. the househekeeper can access between 2 and 4 pm on wednesdays, or giving someone a temporary code). In addition, I see a risk with the aforementioned solutions and that is the fact is that they use relais to switch higher voltages, and relais can often be overrided wit high-power magnets.
What I’m looking for shouldn’t be that complicated… A system that just sends the entered numbers from the keypad or the keychain that is coming from an RFID reader to an ESP32. I can than feed that info to HA and doe validation on it through NodeRed. However, I just can’t find a nice looking system for it. Of course there are simple numapds or PCBs with RFID readers, but I just can’t hang those on my frointoor (and I suck at making nice cages)…
(in advance: not sure if I’m using RFID vs. NFC in their right terminology).
Your question sounds “easy” but has more to it than meets the eye.
basicly you need to “solve” multiple questions
1st how does the door unlock ? electrical on/off (toggle) cilinder or a “smart” lock … pick one, if you need a relay though you can extend the wires to a point out of reach of evil do-ers. Remember to have a key option at all times.
2nd the external tag/keypad reader sends a signal to HASS from there you can add automations/triggers/events for example a calendar event ? or set time that allows acces between X and Y this is basicly a “hass” party
3d how to do it proffesionally with desired options.
I bought a Nuki keylock that at least solved the 1st part, the second part I am building right now.
you can also wifi connection + webhook/webpage .for HASS with “open door” only option depending on your wifi security of course. (companion app + local (aka WIFI) only, disabling remote access)
For an external “controller” via ESP/Arduino/RPI device, just make it send any input to HASS, where HASS will evaluate the input as valid … from button to 10 digit code on the keypad/rfid/fingerscan(ner)
Starting with the button.
A proffesional look well that is the most “easy” part … just depends on your wallet.
