I’m looking for the right hardware to add an usb dongle or other device to my HA server to control a device that works on 868mhz (Niko Easywave buttons) .
I’ve been googling and searching the community and can’t find any reliable help or info. Can’t be the only idiot that has a device that uses 868mhz…
Unfortunately, I directly installed Hass.io, so no chance for installing something on OS level, as far as I found. How to deal with this? I do not want to set up a second Raspi, just for using the RF Link.
Correct, my repo uses a second Raspberry PI.
I need that because my Hass.io PI is 15 meters away and the radio signal doesn’t reach far enough. Hass.io is Linux based, so technically it should be possible to install the RF code on the same PI.
But I’m not tech savvy enough to dig that deep. Give it a try and share.
