I have soldered up an rfLink gateway, which seems to be seeing my devices OK. However, I am running into trouble adding them to home assistant:
configuration.yaml:
rflink:
port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55736323239351311150-if00
light:
- platform: rflink
automatic_add: true
- platform: rflink
automatic_add: true
logs
2020-03-06 19:40:26 DEBUG (MainThread) [homeassistant.components.rflink] event of type sensor: {'id': 'acuritev3_0097_hum', 'sensor': 'humidity', 'value': 65, 'unit': '%'}
2020-03-06 19:40:26 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: []
2020-03-06 19:40:26 DEBUG (MainThread) [homeassistant.components.rflink] device_id not known and automatic add disabled
The last line seems to be why I can’t see any devices…but I am unclear at the moment as to why discovery is disabled…
