I’m just starting with HA ( yes again ) and having some trouble to understand rflink integration.
I have added all the devices to there groups, customize etc sections and everything is working.
Though I have 2 problems i can’t seem to understand.
1 ) How can I remove the light group and only show them in there right group “ex. keuken”
2) when i restart HA all groups and entities are gone from the frontend. when i press the button on the remote they are back to the frontend. How can I force HA to remember there group ( I understand HA can’t remember there state, so this is fine ) and show them always on the frontend.
Bare in mind that this will disable HA to autoadd stuff to the UI, i solve this with view: no when i configure stuff, and then change it back to view: yes when im done.
Dont now any other way, im new to HA also.
I have created groups for the entities which I would like to see, Though when i don’t press a button the group is empty and shows “unknown”
it’s strange that the lights are visible in the light group without pressing a button, which i didn’t created manually but not in there assigned group.
So this is something coming from the component of RFlink.
Before restarting HA should save the state of each device for later use, but this would require a some coding on the component part.
Maybe I didn’t explained my self well.
The problem is that all rflink devices get populated in the light group after a restart.
These devices are added in the devices: section like you mentioned.
After I press a button on a physical remote the devices get populated to the right group like “keuken” in my screenshot.
The second part is that it’s ( i think ) impossible to hide the light group from the view since all devices which are not beloning to a group ( see question 1 ) are getting populated in this group.
But please correct me if i’m wrong.
Below is a snippet from my configuration.yaml which I have so far.
Light > Keukenlamp & Keuken > Keukenlamp are the same entities.
Though only the one in the light group is working.
I tried different types as explained on the component page but this didn’t help.
note: Bureau is a yeelight and not a rf so this is a different light type
