RFLink move from Domoticz to HA
I moved from Domoticz to HA.
I am using Shelly, ZWave, Rflink, Mobile Alerts.
All works fine, i just have a strange issue with one RFlink 433 device.
The switch on command works, but not the switch off (but it is sent, i can see that in the logs). In Domoticz it still works, i copied the ID from Domoticz to HA.
The device is a Led Pool light. It gets for each function only “on” commands.
Following is the config:
#Pool Beleuchtung
  • platform: rflink
    device_defaults:
    fire_event: true
    signal_repetitions: 1
    devices:
    EV1527_000481C8_0:
    name: Pool Beleuchtung ein
    EV1527_000481C8_15:
    name: Pool Beleuchtung aus
    EV1527_000481C2_10:
All work, just not the off
I add the link to the device, no commercial :slight_smile:
https://www.pooldoktor.net/shop/pool-led-scheinwerfer-rgb-mit-einbaunische
Does anybody have an idea what the problem could be?
Br
Michael
